2021 versions out now of PCBCAD51 and PCBCAD720.
Improved error checking in PCB entry. Copper pours out of range design rule check.
Murton-Pike Systems PCBCAD51 pcb design software - Murton-Pike Systems PCBCAD51 PCBCAD PCB CAD printed circuit design software.
Demo version available.
Leave security code blank for demo version.
http://murtonpikesystems.co.uk.servepreview.net/pcbcad51demo.html
Second February 2021 update out now.
Add in schematic sheets from A1 to A6.
Improved printer detailing.
March 2021 update out now.
Improvements to auto routers.
Latest version out now at Murton-Pike Systems PCBCAD51 pcb design software - Murton-Pike Systems PCBCAD51 PCBCAD PCB CAD printed circuit design software.
Quite a good package but libraries arent big.
If you want big libraries then download KiCad if you want bug free software download PCBCAD51 from Murton-Pike Systems.
PCBCAD51 August 2021 version out now.
Honesty bit.
Good bug free CAD but doesn't have big libraries.
However, does have good component wizards.
Honesty bit.
PBC design software latest out now.
Very cheap yet has lots of features.
https://www.murtonpikesystems.co.uk
I am happy to answer questions about it.
There are 2 versions PCBCAD51 and PCBCAD720. Difference is PCBCAD720 has faster redraw due to using .net core.
Runs on Windows XP (SP3) , Windows Vista and Windows 7, Windows8, Windows 10 and Windows 11.
This is a mature product with no bug list, if I find a bug it is fixedimmediately.
Support for this product is second to none, you are supported by the guy whowrote this software.
Schematic and PCB symbol designer wizards.
Auto creates SIL, DIL, BGA, circular and QUAD PCB footprints from yourparameters.
Schematic entry with auto convert schematic to PCB rats nest, unconnected pinscanner and single ended net scanner.
PCB entry with 127 layer rip up and retry auto-router with clearance andcontinuity check.
Gridded and grid less auto routers.
360degree rotations of pcb components with obround pads.
Integrity checker, compares schematic and PCB for differences.
Component locater.
Parts list output to file and to printer.
Schematic/PCB component auto-renumbering and re-annotation.
RS274X Gerber file generator and NC/Excellon drill file generator.
Pick and place file generator with fiducial option.
3DPCB viewer module. (for this software output only)
Output schematic to printer auto-sized.
Output PCB to printer in 4:1, 2:1 and 1:1 scaling, inversion andmirroring about x and y axis.
Merge schematics and merge PCB's.
Library scanners for fast component selection.
Gerber file viewer (for this software output only)
Component locater, block-mode for repeats, shifts, rotations etc.
Net optimizer for shortest routes.
Auto component placers for minimum routing.
Recursive auto-autoplace, rotational autoplace and swap autoplacer.
Auto-place and route recursively function for lazy PCB design.
Unconnected pin scanner.
Forward annotation function from schematic to PCB.
Screen capture to bitmap file in schematic and PCB entry.
PCB's up to 50 by 50 inches.
127copper layers.
127resist layers.
Copper pours, each layer can be connected to a different NET.
Two silk layers (upper/lower)
Comes with basic symbol libraries, 4000, 7400, smd4000, smd7400 and general as standard.
User manual in each module
This is the full version and not a crippled, time limited or downsizedversion.
This is a fully integrated package and not a suite of amateur freeprograms cobbled together.
Fully supported package with email and phone help lines.
Added jpeg screen grabs instead of .bmp screen grab.
PCB design software at https://www.murtonpikesystems.co.uk
model railway bits and pieces at www.platformfour.uk
August 2022 version of PCBCAD51 and PCBCAD720 out now.
Downloads or CD version.
USB PC oscilloscope with analogue display and spectrum analyser display.
20 mega samples. Bandwidth up to 1MHz.
https://www.ebay.co.uk/itm/255533596571
September 2022 version of PCBCAD51 and PCBCAD720 out now.
October version of PCBCAD51 out now.
Improvement to gridless auto router added.
- Vendor's Bazaar
- Nigel Wright's Vendor Thread
