Newly built, LCRs with AE TD12 M and Beyma TPL 150H, advices welcomed
BEYMA AMT VS COMPRESSION DRIVER
I am interested in a remark, or a link to discussions when it comes to comparing a top notch amt driver like the Beyma, against a ditto compression driver. Specifically:
I listened to the TD12M with a compression driver this week, and while the speaker is really great, I could not overhear a certain dominant in the presence frequency area, as I have heard so many times before from compression drivers.
I have a Mundorf AMT29 (100dB) pair which I consider pairing with one or two 12/15 inch drivers, for example TD12M
Thanks for any response.
I just finished some cabinet building where Acoustic Elegance TD12M + Beyma’s TPL 150H shall replace existing LCR ......
Note that I am in ignorance on compression driver constructions. Answer: No, but the speaker was announced "speaker of the year" in 2018/19 by the two hifi magazines here. It is a good speaker for sure. The compression driver and horn is off the shelf, which might be NOT the way to do it. I am not chasing "horn on compression driver" as a bad solution. I am asking if the mentioned effect is a "tendency" from compression driver constructions unless you are very careful with the design. Yes or no?
I listened to a YT interview with Earl Gedde and there he discussed that issue, speaking about his "foam" solution that is probably a remedy. It was related to his oblate spheroid constructions, which I find interesting, specially after reading his book on speaker constructions.
So let me ask another way: If a horn+compression driver is properly designed will it then be completely natural (or exact to reality if you will), and without any of the said tendency? Yes or no?
The general consensus around here says Yes. I had a chance to play with an Altec 2 way using a 511 horn, and its one the highest SQ experience I've had since. Resonance was the last thing on my mind. But it was also a really nice room. I'm actually trying to create my own version of that experience, currently. As you say, design choices are important.
