newbie recomendations please
I've never built a tube amp, but I've built 3 ss amps. I have 85db rated speakers at 4 ohm (magneplanar MMG), so I reckon I need about 30 to 40 watts power. What would your recomendations be for an ambitious first tube build? :xeye:
I've been following the thread on the 6c33c with some interest, would you consider this a good project?
Kev
The MMGs have quite a varying impedance curve, going as low as 1.6 ohms if I remember right. They're also very power hungry. A push-pull pentode amp would be your best bet. I know one guy who ran his MMGs off a vintage Fisher 400 and found it quite a good match. If you're looking for PCBs, DIYtube offers inexpensive PCBs for building a clone of the EICO HF-87/89. You might also consider building a clone of the Dynaco ST-70 or MKIII.
Thanks for the info, I didn't realise the MMG's were such a difficult load, I knew they were power hungry, but didn't know the impedance went down to 1.6ohms.
I'll definitely do a bit more research on the configurations you suggest
Kev
