Haven't bought a new iron yet for my rework, been busy but I will soon.
HOWEVER... I've made a new purchase!!! I saw this Hifimediy new T2 amp and it MADE me buy it. I had wanted to try the new Nichicon KG 10000uf cap T2, but didn't want to **** the wife off. Then I saw this NEW VERSION.
Hifimediy T2 special version 2*100W@4ohm amplifier STA510a (Nichicon KG 10000uf)|Hifimediy
Can't wait for it to arrive!
Later dudes
Later dudes
T1-M is a new board will beat TA2024/2020/2021. Based on TC2000+STA505/TP2050 chip set, this board can use power supply from 9V to 24V DC and output up to 40Watt@4ohm or 30W @8ohm.
Here is the photo.
Any updates on pricing and availability on this unit?
@hifimediy
my TA2050 / T2 fail to power up, red LED is blinking, power input is 36v
what is the root cause of this problem ?
help help
36 is a too high (from the specs), but it should still work.
if the red led is blinking, it suggest some bad connection from the PSU, or on the few parts from the input to the led, or the led itself.
@hifimediy
help help
First of all, check the PSU is ok or not. Or the board has problem, may be the output chip is burned, which lead to a large current from PSU and the red LED blinking.
hi,
The poster with the problem above is my colleague. And I think it is a T1 STA510. In case of burned chip, is it possible to get a replacement ? For info, the PS is from Connex Electronic. I uses same board with Meanwell without any issue.
Thanks in advance.
Here is the photo.
Any news?
This looks like it, but unfortunately I don't know Chinese, so this could be wholesale rates?
T1-M¹¦·Å°å TÀàÖ±Á÷¹©µçÒôÁ¿¿ØÖÆ ¿É³µÓÃ-ÌÔ±¦Íø
HiFimeDIY ÌÔ±¦µê-¼ÒÓõçÆ÷/hifiÒôÏì/¶ú»ú - ÌÔ±¦Íø
Hi, I recently purchased a pair of Pioneer SP-BS41-LR (85dB sensitivity, 6 ohm impedance) and have been looking for a quality budget amp solution. After spending some time researching the Dayton DTA-100A, I read that these amps were better built and would sound better. Any suggestion on the best board/power supply combo for my new speakers? Thanks in advance!
Any news?
T1-M TK2050 amplifier. Accepts from 9V to 24V DC supply voltage. Output power between 2 x 8W and 2 x 50W@4ohm|Hifimediy
it appears to be on the site
Would be interesting to see some measurements of all Hifimediy amps!Would be interesting to see a noise measurement.
T1-M definitely looks interesting.
How would the amp work with shared power source?
Any special needs for grounding or concerns if left floating?
I would have no problem measuring it if I get one, although I don't want to buy a few and then find out they won't meet my requirements.
S+H does add up in you don't buy more than one.
..OK I couldn't resist and got some. Especially as I saved from getting recycled some quite suitable power supplies that have been sitting in the garage. Maybe I should have just got one but I got more to save on shipping. They just arrived today.
Powered it up using a 50W 20Vdc SMPS. Listening using Econowave speakers, Elliot Sound Products p88b preamp, Hifimediy DAC.
Quick listen to a few tracks just now and it is quiet, has clear sound and good bass for its power. Better than I was expecting! Haven't listened enough for any firmer opinions to form.
It runs very cool. Measuring on my steplight power usage meter it consumes 2.7W power idle, and doesn't use much more power playing at low-medium volumes.
I like how the heat sink goes under the PCB, effectively making it a stand for the board.
Please do write more about sound quality.
From which drivers are your econowaves made off ?
My speakers use Selenium d220ti compression drivers + Pyle JBL clone waveguide, and Eminence Delta 12LFA woofers.
The usual amplifier I use is a ConnexElectronics TA-3020 v3c with 500VA toroidal transformer, sometimes I switch to a Hifimediy T2 with 160VA toroidal transformer. Sometimes I unplug the passive crossover and use both with a miniDSP. All these combos sound great
A bit more listening and perhaps the T1-m has a slightly thinner and "chalkier" sound than the above two amps (which cost, respectively more than 2 and 4 times as much, not including power supplies), but this is only a slight difference.. it is very detailed sounding amp, and it's remaining plugged in for now... a suitable nice off the shelf enclosure will cost more than the amp itself... I'll drop it in a jiffy box so I can use it safely.
- Class D
- New TK2050 board
