Take a look at this site:
http://www.transmissionaudio.com/pages/738782/index.htm
Everything what is announced there looks nothing but impressive to me.
Ultralow distortion, extremely high max. SPL, perfect impulse response.......
It seems almost too good to be true...
Read Yourself....
Read Yourself....
So in order to hear one of these most of us will have to DIY. I think there is enough information divulged in the photo to take a stab at making one.
You might want to wait a little until it`s out what these ribbons will cost - when the price is according the claimed specs - it likely will be highest end.😱Where do I place my order?
I`m anything but an expert in DIY ribbon speakers but I fear this can hardly be DIYed.
At the site they stated it took a decade to fine tune this technology.
Not that I believe manufactorers claims blindly but all this really looks like there is a little more involved than just a lot of magnets and aluminium-foil (or copper).
For example, how they manage to drive the ribbons without a transformer?
How it`s possible to make the suspension of something so fragile like a ribbon diaphragm floating?
Also X-max of up to 25 mm (1 inch)
If this sounds anything like Apogee speakers, I'll be the first to purchase a pair. The pricing of these speakers will probably prevented me from buying them in my life time.
Well the inventor created it through DIY didn't he?
you guys want to make guesses on price for the units?
ahah 😛
i'll be waiting for prices before construction my ESL then ..ahah 😛
ahah 😛
I have issues with some of the claims. a quick example is: The high conductivity of the ribbon element means that it's not uniformly driven.
He apints with a rather broad brush when it comes to comparing the other technologies.
I'll believe it when I see it.
I'd like to see some data. Marketing babble gets old quick.
Sheldon
Sheldon
http://www.transmissionaudio.com/images/170_Wave_Web_kHz.jpg
This looks hard to believe.
http://www.transmissionaudio.com/images/168_Pulse_resonse_Web_168.JPG
(censored)
(censored)
454, I had to manually edit out your attempt to get around the obscenity filter. That's extra work for me (unpaid work!) and gets me cranky. Please don't do that again.
So, after reading through the pattent application, im still a bit confused... What is actually different about these ribbons? It probably has more to do with my lack of understanding in how normal ribbons work.
Chris8sirhC - You're not alone wondering. I'm no ribbon expert either, but it sure sounds like he claims the prior art. There is something about an opening behind the ribbbon that may be novel, but it sure doesn't sound like the strongest patent application.
Then again, B*se seems to be able to patent the prior art pretty regularly.
Ive seen a dipole ribbon before, so its not like that is anything new. The only other thing i can really gather is that on one of the designs the pole piece is inbetween the magnets and the ribbon (....I think???) and he doesnt have to use a transformer to drive it.
www.audiodesignguide.com/mag/index.html
Interesting, I am a little baffled about how it is possible to achieve
a decent ribbon transducer with a ribbon width of 8cm without resorting to huge magnets or some planar arrangement?
My own limited ribbon transducer experience is designing a transducer for headphone use.
As for theirs being the first ribbon headphones ,I believe someone designed a pair in the 1930s and I had my first pair up and running in 2001.
Setmenu
Setmenu
Patent looks like Series Xover for Ribbons
The patent by TransmissionAudio that SY referenced appears to be an attempt to patent a series crossover for ribbons that is in common use for dynamic speakers.
Ribbons have a very low impedance, often < 1 ohm, and a step-up transformer is typically used to create a higher impedance between 4-8 ohms that most amplifiers can drive. This transformer inserts phase, step response, and frequency limitations. A good transformer is expensive.
By putting the midrange and tweeter ribbons in series, along with series passive components for crossover and equalization, one can create a higher impedance, more amplifier friendly load. This removes the cost and performance limitations of transformers, and allows one amplifier to drive multiple ribbons with greater fidelity and lower cost.
For long, wide bandwidth ribbons, I have found that a low impedance direct drive amplifier is required to mechanically control the ribbon's movement in the magnetic field. I have built Class-A amplifiers that sound very good driving a 0.5 - 1 ohm resistive load, which thanks to low 7V output power supplies, are modest in cost, heat and size.
Nelson Pass as part of his First Watt efforts has published a few articles on current source amplifiers and series crossovers that cover the same ideas as in this patent. Nelson has also discussed using a current source amp to drive (tweeter?) ribbons.
http://www.passlabs.com/np/CurrentSourceCrossoverNetworks.pdf
Another new ribbon is made by BEEngineering and is featured
on www.E-Speakers.com down to 300hz! but do be seated
when you read the price.
Woody
Woody
These are the guys who made the ribbons for Mark Levinson's Red Rose speaker systems. In fact, if I read it correctly, they designed the entire Red Rose speaker line, not just a supplier of the parts.
Those speakers (especially the little one's) got a lot of nice reviews. So the new ribbons are better. Where's the project that proves that? And what's the cost?
Enjoy,
Bob
Enjoy,
Bob
- Planars & Exotics
- New Ribbon Speaker Technology - Approach the perfect speaker?
