As I said in another thread, a measurement device is a must, but before you should use some simulation software. If not you are basically shooting in the dark. I can suggest you to read: FRD Consortium tools guide
As for the mic, most (all?) electret mics need phantom power, and gain, and in short you need a suitable preamp. I built the Neal-Wallin preamp (Microphone Preamplifier Project), connected to a cheap external sound card.
You also need a device for measuring the impedance (and TS parameters). I built this really simple and effective jig: AudioBlog: A simple loudspeaker measurement jig for ARTA
Ralf
Ralf
FWIW : https://sites.google.com/site/undefinition/diy/amiga
both drivers are relatively cheap from europe audio.
or on a seriously low budget :
http://oaudio.de/Loudspeaker-DIY-kits/Floor-standing-loudspeaker/MarkStart-white-Kit-MKII::804.html
rgds, sreten.
rgds, sreten.
Thanks sreten, the amiga drivers look interesting. A little too low sensitivity for the woofer, maybe.
Ralf
I've got an EMM-6 with a blue icicle usb adapter that supplies phantom power. It's cheap and seems to work really well.
http://www.amazon.com/dp/B001EW5YQS...e=asn&creative=395093&creativeASIN=B001EW5YQS
http://www.amazon.com/Dayton-Audio-...cal-instruments&ie=UTF8&qid=1329311117&sr=1-1
For less than 100 bucks you can have a mic setup that requires nothing but a pc with a usb port.
True, it is low sensitivity but the consequence is excellent bass extension.
TBH I'd much prefer living with the deeper bass than fretting about party
levels. In the end maximum levels depend on bass unit excursion, not
the sensitivity as long as you have enough watts, and the amount of
watts a 6.5" can take goes down the further you extend the bass.
96db to 98db in the bass needs a 30W to 50W amplifier.
If you want party levels build a standmounted sealed box and crossover
to a subwoofer, or build some speakers that can party with the best like :
https://sites.google.com/site/undefinition/tarkus
YMMV but the RS180 is a great driver for its price, clean bass being one
of its strong points. IMO you can't do better for the price than the driver
pair in the Amiga in Europe. Or the design probably for the price.
But it not you that needs pleasing, its your friend.
IMO opinion he (presumably) would be happy for the price of either
designs I posted, and TBH you would be a lot better off not being
responsible for the design, if you haven't done a design before.
The cheaper speakers may be all he needs, the Amiga is serious hifi,
and needs a good CD player (~ £30 used) and amplifier (~ £70 used).
A Marantz SE is good for the CD and a Pioneer A-300X for the amp.
If its not that serious build the cheaper speaker, they look great value.
rgds, sreten.
Hi Starre,
Actually this level of sensitivity is quite good knowing RS 180 is
8 ohms. Comercial boxes like Amiga would be in most cases
4 ohms, hence more SPL.
Amiga project looks very interesting and promising. I wonder why
there is a 2-4 kHz gap. Perhaps this will be taken into account in the
next x-over version.
I am sure it is a good driver sreten, I am just not ready to decide yet I have noticed, thanks for your input.
Hi Lojzek, yes it seem to be a good choice for decent money. At the moment I find myself looking at more and more expensive woofers, but we will see what I decide.
I have actually decided one thing, I will do a vented design to keep the speakers small but with some deep bass.
henry, it is best suited for a sealed design, right? Wanting a bass reflex.
This driver seem interesting, a little expensive (about 75 Euro) but nice:
H1571-08 U18RNX/P
H1571-08 U18RNX/P
Comments on this?
It will be a 2-way bass reflex speaker I will try to build for a friend of mine.
This is no longer true ? If it is true forget about expensive
drivers, you should be concentrating on bang for buck ...
rgds, sreten.
Idunn if you like that Seas driver
Sb17 suitable for 15L br, u can check jeff bagbys mandolin kit for meniscus. They are the best performance vs price ratio. Well built, and superb sound.
Cheers
Henry
Cheers
Henry
I am now building a test cabinet about 25 litres and got some components for crossover test. Post a pic of cabinet when done.
Cabinet almost ready, some adjustments and driver installation left. Looks promising to me.
Cabinet is 28 litres, thinking of testing woofer in closed box first and measure the woofer.
Since some earlier posts are missing I can inform that drivers that will be used are seas 27TFF and
CA18RLY.
CA18RLY.
Made a simple filter with 1mH for woofer and 10uF for tweeter. Playing at low volume, the tweeter needs attenuation a few dB. Posting some measurings next time.
- New project.
