The KSA/KSC predrivers don't do well at low Vce. I suggest the BC5xx or BC3x7 instead. They are not in any danger of overvoltage.
OK, i will try it. You think it can work in reality?
I'm sure it can work. I've done a lot of stuff in simulation with this kind of OPS, but I haven't built anything with it yet.
Whats so fancy about it? Its nothing new but definitely good performance.
It is cool and new for me as newbie 😎😀
So, I ask who have more experiences than me.
The two peaks (58Hz & 40kHz) probably indicate the need for some compensation of a local loop are two.
I don't know where to point you to find the errant loop, but an RC for pole and zero is probably needed for each resonance.
This is not the frequency response but PSRR.
There are no peaks at the frequency response and it have good phase margin and gain margin.
Why not using this super pair on output transistor ?
It difficult to set the bias.
the closed loop frequency response and phase tells us nearly nothing about stability.Add R C to smooth high frequency (just in case). This reduce PM and GM slightly but THD and slew rate is not changed.
Go back to your PSRR.
15.38Mpixels is a bit much for my screen.Schematic.....
How about ½Mpixel to 1Mpixel pic of the sch, depending on what you think is legible?
Reduce the resolution, but you can "zoom out/in"
- New Output Stage?
