• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
new Optical pickup and spare parts arrive
KSS-151A, KSS-273B, KSS-240A, KSS-720A, DAX-23E, DAX-25, CDM9/44, SF-DB23, SOH-DL2D...
large stock of laser pickup use for CD, VCD, DVD player, laptop, AUTO
feel free to contact me for more infomation
Free shipping by DHL, UPS, FEDEX for every order up to 1500.00 euro(or 2000.00 USD) from 7th to 27th, September
dora_component@homail.com
hallo,
I need data sheet so as successor types of no longer available Sharp hologram laser diode, that inside in all Philips CDM12 and VAM variantes. The type is follow:
LTOH30PA (LT0H30PA)
Additional I need a successor type of SONY's diode SLD104AU and SLD104BUL Datasheet see about
http://www.datasheetcatalog.org/datasheet/sony/a6802787.pdf for SLD104AU, 5mW and
http://www.datasheetcatalog.com/datasheets_pdf/S/L/D/1/SLD104BUL.shtml for SLD104BUL, 10mW
This laser diode are inside of no longer available optical pick ups from SONY, e. g. KSS-151A, KSS-272A until KSS-274B, KSS-280A and KSS-281A
I will try to replace this laser diode. Therefore I need currently types, that are compatible both mechanical and electrical.
In this case I start two threads here - there you can read more in this case:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=148561
http://www.diyaudio.com/forums/showthread.php?s=&threadid=146350
perhaps you can give me appropriate advices - thank you very much.
Laser diode successor available as high power and extended live time version (SLD-304) for KSS-151A, KSS-273B, KSS-274A, KSS-273A, KSS-272A and many more pick ups from the KSS-series:
5pcs Sony KSS-151A KSS151A Laser Lens LD Laser Diode | eBay
2pcs SONY KSS-151A 3mw-5mW 780nm 5.6mm TO18 Infrared IR Laser/Lazer Diode LD | eBay
I still hold the last one of KSS-273B - Agoraquest - Sony Forum, News, Reviews
Datasheet:
http://pdf1.alldatasheet.com/datasheet-pdf/view/47610/SONY/SLD304V.html
