Konnichiwa,
No idea, they are listed at 400VA/230V. They are for mains filtering.
The ripple, I forgot, but it was a few dozend mV peak-peak, right in line with Duncan Amps PSUD predictions, something like 10mV or so RMS, 100Hz with a very nice round waveform.
Sayonara
Gluca said:...and what's the max current the chokes can swallow
Gluca said:...and the ripple you get?
Sayonara
The circuit using mercury rectifiers posted earlier in this thread got me thinking..
What about Tungar bulb rectifiers ? Designed for low voltage high current applications. Has anyone tried this out for heater supplies ?
The common mode choke
Kuei,
I am working on a project using 2A3s and would like to build a PSU similar to the one you presented here. I read your postings in this thread and also on Audio Asylum but could not find the specs for the common mode choke before the 300B heaters. Could you tell me more about it?
Kuei,
Re: The common mode choke
Konnichiwa,
It is an absolutely generic 5A common Mode choke, quite large size/core. I originally got a load of them when work threw out around 100pcs of Compaq PC's years ago. I actually salvaged parts from all of them (on company time, I was required to destroy the Harddrives for some stupid reason), especially Chokes, MKP Cap's, some of the PSU cap's from all the PSU Boards I pulled and loads of rubber HDD mounting gromets. Great find. I'm still using up the stocks
Sayonara
Konnichiwa,
grimberg said:I am working on a project using 2A3s and would like to build a PSU similar to the one you presented here. I read your postings in this thread and also on Audio Asylum but could not find the specs for the common mode choke before the 300B heaters. Could you tell me more about it?
Sayonara
Kuei,
Are you saying regular PC PSUs have them? I have a few old ones lying around; I think it is time to take them apart. 😀
What inductance should I expect to measure?
Konnichiwa,
Yes, but often the quality is crappy. Have a look. It sits right next to the Power Input and the higher the power of the PSU the better. The old PC's I salvaged where from high spec 286 PC's with 250W PSU's, even better sat in 500VA Server ones....
Sayonara
grimberg said:Are you saying regular PC PSUs have them?
Sayonara
