New high end, high power MOSFET amp
I have been recently thinking of building my own amp that can properly drive my Kappas 9.2i and any other future Infinity's I'm going to own.
I have not much experience with building electronics, besides recapping some old amps and reading a few books a long time ago. But I love playing around with this kind of stuff. So I would like get some input on where to begin.
I want a BIG and powerful amp capable of delivering at least 300 watts at 8 ohm and being stable at 1 ohm. MOSFET or SIT. Also playing first 20-50 watts in class A.
I know this will be expensive and maybe difficult to build, so I'm looking at this as a long term project.
So, where should I begin?
Can I use some of the Firstwatt or Pass schematics?
Have anyone here build a similar amp?
Sounds like serious project. Big and expensive.
Do you meant it has to be stable ar 1 Ohm, or does it have to deliver enough power as well? What output power do you expect at 1 and 2 Ohms?
Pass circuits are very good starting point for characteristics you have described.
Firstwatt are rather low power, but some of them are quite scalable.
It is not the only way, but very reasonable for your case.
Baby steps: If you rub one of Nelson's Adcom 5400 amps the right way, you're halfway there...
Could this amp be something for you.
Thel Audio Accusound 100 .
Switchable between Class A and Class AB .
DC protection onboard , voltage rail from 20 Vdc and 95Vdc and 1 Ohm stable .
More info trough email .
Reactions: Gill.T
