• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
New FIFO buffer for RPI/SBCs
Control and voltage board!?!?
What's that for? Do we still need external power supplies?
The seperate output-stage board might be a nice approach. It'd perhaps allow to add another output stage in the future. We discussed this earlier. That's potentially quite nice and (hopefully) keeps the solution flexible.
I guess there won't be a need for a Kali or any other isolator board or similar!?!?
What I also like with this approach is its flexibilty. Perhaps there'd even be a chance to swap just the DAC chips (Q2M->Pro) and still use the other boards in the future.
Obviously all that will come at a cost. The Audiophonics ES9028Q2M
sells at 129€. And the Ebay ES9038Q2Ms at 40$.
Lets see how that will look for Katana. :D
Hello ES9038Q2Ms 40$ from ebay has quite weak LPF differential single ended buffer, i guess thata katana will be different league, PRO chips are power hungry ...ES9028Q2M is worse against 9038q2m for SQ
