Just installed a vanilla Raspbian Stretch and stock kernel 4.9.47.
Allo didn't manage to get the updated driver into 4.9.47. 🙄
I would like to buy an Allo Reclocker, with this new dac, how to use it or will not it be necessary and then i save the purchase?
Are there news about the new dac?
Great! I also rely on digital control.Yes of course that volume will be supported .
This sounds like a great product. Can't wait to hear one
IMHO the possibility of disabling local power supply (supplies) without desoldering smd components will be great.
Hifiberry Dac+ Pro with separate 3.3 V ps for digital part and 3.3 for analogue part is completely different dac, but i had to bent some pins on pi, desolder smd parts and solder few things to reach that. One good external power supply is (nearly) always a great improvement for any audio gear.
Maybe also a possibilty to exchange easily outputs caps and resistors (if any)...
I am thinking of using the Kali with an external I2S DAC (DDDAC-1794), and then feed the analog signal from the DAC to an Allo Relay Volume Control. The plan would be to stick the Kali on an RPi, and the Relay Volme Control onto the Kali. The DAC would not sit on this stack. Will this work? Will the Volume Control fit on the Kali? Are the I2S pins accessible from the Volume Control board to feed them to the DAC?
Not possible , sorry we did not design it with this config in mind
How "not possible" is it? Is it just the connectors not matching up? This would be easy to solve using jumper wires or similar. Or is there some deeper issue with the protocols of how the RPi and the volume control talk to each other?
i2s pins are not available on att relay. This is the first issue, I will need to check all pins and see what else I can find (as problem)
Ok, then I can take I2S signals from the Kali. Then interface the Volume Control to the Kali using jumper wires for the GPIO pins. I'll give it a go and see how it goes...
Might be a simpler solution to use Kali on RPI3 and relay hat on a pi zero
Can I tell Volumio to use the RPI3+Kali for music playback over I2S and RPI0+Relay for volume control?
Allo, anyone here?
Seriously though any tentative release date for this DAC and will it be compatible with your Sparky board?
Hi
no tentative release yet...not compatible with Sparky because it needs a SBC that allows to be slave to codec.
Sorry if I am hijacking this thread. But as far as I understand you designed the Kali board?
I have a problem. I bought the Kali + Piano 2.1 + Volt to use with Kodi and MPD (audio switching between the two which seems to work).
Now I have the following issue:
Audio delay when using Allo Piano 2.1 DAC + Kali Reclocker
I do not really want to throw it in the trash of course (sorry for saying that) and actually think the hardware is well designed, but I was shocked when I learned the Kali cannot be used when playing movies in Kodi because of the introduced audio delay which varies every time.
Is there a way to solve this? I already spent almost 200$ to buy all the boards + power supplies 🙁. They sent me the wrong 19v psu (connector too small) and forgot to send me the spacers (received them later, but still not enough). Cannot wait to be able to enjoy this, but feel bad about having spent so much money and not being able to use it as I intended (being able to control the subwoofers separately using the LFE inputs for movies and listening to music of course, but that works fine)
I was going to get the Kali board, but I am not in a rush to get it. So I guess I can wait until the Kali 2 is out.
cdsgames, I'm also interested in the release date for this and if you have any further info on the "new amp project" which you mentioned on the last page.
Thanks!
Thanks!
- Vendor's Bazaar
- New FIFO buffer for RPI/SBCs
