New DHT heater
I have a big three stage all SET amplifier in place with three separate anode supplies and six heater supplies. I split it into signal part, filament supply part and anode supply part and connect everything with umbilicals. When I still had the floor space and no kids I had everything on wheels.
Reactions: Fuling
Yeah, nothing wrong with small amps but the bigger ones are simply more fun!
Hi Ian,
I assume you mean 2-parallel push pull per channel?
I certainly have solutions for it in any way they are combined.
For 2-parallel, if the cathode point is the same place for each of the parallel 300Bs, you can share the regulator - but the downside there is that the individual bias of each 300B must be made on the grid, if you want to have it individually adjusted; otherwise one filament rregulator per 300B, and slight variation of the cathode resistor.
Else - let me know if I guessed wrongly!
Yes,
2 parallel push pull per channel.
I have Menno/Guido bias servo boards to handle the Bias BUT that needs separate cathode current sense resistors (0V side) for each 300B (each board handles 4 output tubes so 1 in each monoblock).
Can I still share the regulator on each of the push pull sides such that I need just 2 regs for each monoblock?
While the Plitron Power Tranny has 6.3V @ 6.8 Amps heater winding that will end up driving Preamp/Phase Splitter and I will need (I believe) a dedicated supplementary tranny for the 300B filaments.
Thanks,
Ian
Hi Ian,
Sharing the filament supply (of any type) effectively shorts (or applies low R across) the cathode points of all the DHTs involved in the share.
So if there are individual current-sense resistors for bias adjusment, the controller won't set each bias correctly.
If you have grid bias with current-sensing in the anode supply, you might adjust the grid bias individually, while all the cathodes are at ground. In this case, the PUSH and PULL sides might have one regulator each.
