Neo Magnet inventors are facing shortage
induction motors don’t actually have “electromagnets”, that is their greatest advantage. I wonder when all this hubbub over good permanent magnets will force an industry wide switch back to variable frequency drives, and “the hell with BLDC”.
The higher end use is in, that will be difficult to use alternatives or do away with -
1. Wind Power
2. Tide Power 3. - Any power that is now directly derived as per new green initiatives.
3. EV to give the initial torque -
Basically it will crash all the green targets COP 29 - these targets have been signed off - and it will be a bureaucratic and leadership challenge to move away from these targets.
And now to achieve these targets the - Motors & Entire assemblies or sub assemblies - have to be made in the location with this recourse.
Including - Speakers , the freedom to use off the shelf neo mags and design own speakers - without having to order the the entire motor structure form a the region with the material is not available.
Actually they do, the stator is electromagnet with all the windings to create a rotating field. The rotor is a simple ‘squirrel cage’ with iron bars. that get the induced torque. This is the greatest advantage and also can be done cheaply and no short supply of raw materials.
For EVs however, this torque from induction type motor is not that great for pulling and losses in the rotor. so the use of strong neo mags in the rotor itself to create something better re: video. But neo mags from rare earth supply issues …
Technically, they are all electromagnets - I just meant it’s not a field coil that just wastes VI all the time just to get it magnetized. Losses in the rotor of an induction motor are proportional to load.
The speed/torque curve is the problem. There is a VERY narrow range of slip frequency where they are Worth A Damn, and if you want efficient operation at max power at ANY rpm, the voltage and frequency need to vary. Sine wave operation is preferable. 3rd harmonics are NOT good in a 3 phase system, and the effects of 5th and 7th fight each other. That used to be an SoB of a problem, hence the move to BLDC where pulse width is all that is needed to vary the speed. Electronic commutators are relatively easy to make, and fixed Vcc can be used. The price is the need for a permanent magnet, or the waste of a field coil.
Reactions: acko
