Need Help With EZ80 Rectifier
It would help everyone if the OP would start by answering the questions that have already been asked, even if one or more responses are "I don't know". There is a consensus of comments about the wisdom of using a tube recto in this circuit, and several pieces of advice have been provided without acknowledgment.
I’m not sure why this has become so difficult. I never said that DAC uses tubes. The BP DAC product has a EZ80 rectified power supply. Can any tube guru help me figure out the schematic for it?
I’m sorry, but we are trying to help you. Unfortunately we have, evidently, no clear idea what you are asking!
It seems that you don’t need a tube rectifier to supply a DAC, unless it is a tube output. So, why do you need a tube rectifier?
Let’s start with a first simple question. What do you want to power with the EZ80 tube. Please be specific. What Vdc and current?
I don’t have access the the PCB for the rectifier. If I did I could easily figure this out myself. I just thought someone here was knowledgeable enough to know what the schematic would be given the very few components that are clearly on the PCB, the fact that the transformer has center taps that bypass the rectifier PCB, etc.
The hostility to my question here is really bothersome. I have been on this forum for years and never had any issues. My original post asks "Can anyone help me figure out the rectifier schematic and the proper component values and voltages for the transformer supplies?" Why has this become so difficult?
It's an incredibly poor use of a tube rectifier and it's a gimmick to make their product stand out. They feed the output in a cheap 78xx regulator anyhow. Everything about the design is bad. Like I suggested before download PSUD2 and it will do an exact simulation.
Any power supply design MUST start from a specification of the power required.
MUST!!
You have asked "how can I feed people?", but not said how many people or how long.
Is that a TO220 regulator chip on the lower-left PCB?
Things aren't as complicated as people make them out to be. The tube feeds an 8 volt regulator so as long as you give the regulator enough headroom you'll be fine. Figure on 11 volts minimum output and adjust your input EZ81 input voltage until you get your desired output. Maybe simulate it with the maximum current draw that the EZ81 is rated for to be safe.
The sad (or funny part) is that the EZ81 is probably dropping more voltage than its outputting.
