3 tweeters in a line like that will comb filter like nobody's business, and the distance between your mids will cause a fair amount of cancellation off-axis as well.
Imaging can be room dependent - how close are the speakers to the side walls, is there any sound absorbent material at the specular reflection points?
Would you think a 3 tweeter in verticle arrangement would be any better? How about ina triangle in close proximity (would look butt ugly though)...
"Fostex" is a real supertweeter...Would you think a 3 tweeter in verticle arrangement would be any better? How about ina triangle in close proximity (would look butt ugly though)...
DO THE MEASUREMENTS. It's real world stuff!
yeah i whole heartedly agree.....just dont use a cheap behringer mic
at least spalash out and get a sennheiser or something decent...puleeeze
This is why I've suggested Holmi. It has automatic gating which is very useful for a beginner (in measurements)
You can't just plug manufacturer's FR and impedance in the crossover calculator and expect perfect results because the crossover will have a significant effect on the phase of each driver there for an overlap and the summed up frequency response. The baffle, it's size and the driver placement will affect FR of the loudspeaker as well. Baffle step loss comes to mind as well. Off axis response can make the loudspeaker sound great or bad in the room depending on the crossover. So, no. You can approximate the results in the crossover design software but the real world measurements and understanding is the key to a great sounding system.
If you have ECM 8000 already, all you need is a Behringer or other cheap mixer. Make sure it has phantom power supply for mic. ECM 8000 is probably the best or one of the best inexpensive measurement microphones. You can also have it calibrated for $50 if I am not mistaken.
Have you guys had issues with the (using Holmi) PC or laptop whereby some software EQ'ing or other trickery interfered to make the laptop speaker sound half good and thereby the signal not being flat?
Or should I install Homi in 2 pc's then measure one with the other...to calibrate the first? I am going nuts now.
at least spalash out and get a sennheiser or something decent...puleeeze![]()
why not? for FR measurements Behringer will do just as good as any other. Calibration is where you gain precision and credibility.
K-aml, you need to disable all the EQing in the windows. It's the settings issue.
Go on the Holmi thread and ask.
drop tweeters and move mid closer
you have too many tweeters that are interferring with each other and the mids
You only need one tweeter and move the mids closer together after doing that
and have the mids done in parallel and the more narrow the baffle the better
Ok since the term comb filtering was thrown out twice... I needed to ensure
1) I understood it
2) Considered it beforerippingout my current design...
I took to the sometimes trusty google and came upon an article written by a designer in a well known speaker company and here is a what he said in a nutshell..
You guys tell me if I should think of it as a huge deal... and I quote:
"Comb filtering is a catchy audio phrase that's used in audio discussions on forums, in articles, and often in the context of critical comments about the specifics of a particular speaker design. The fact is that comb filtering is simply a measurement artifact and does not detract from the listening experience. The research shows that comb filtering is not detrimental to accurate loudspeaker sound reproduction; at worst, it's irrelevant, at best it actually adds a pleasurable element of spaciousness to stereo and surround sound. "
1) I understood it
I think you'll find that's a minority opinion....
Everything depends on the details and none are given so its audibility cannot be determined. Some "comb filters effects" are inaudible, others are, it all depends.
Installed the W4-1720's. Not bad.
Fine tuning the xo by ear. Sounds Like the P13 but with more details.
More later.
Question: why is comb filtering not an issue in D'appolito configurations, after there is FR overlap between adjecent drivers....
More later.
Comb filtering is mostly an artifact. The mic is a single small spot, your ears and head are not.
So you don't get the same sort of cancellations that a single point, like the mic, does. As Gedlee points out - sometimes it matters, sometimes it does not.
I usually measure only one speaker at a time, not the pair. I do think that with all the drivers you've got on your baffle, comb filtering is going to be an issue. The higher the freq., the worse it will be. That's why you got so many comments about multiple tweeters.
- Need help... will pay for small service.
