Need help. Strange sine wave on outputs.
Does the DC bias control now work, and vary the DC voltage at the 300B grid?
Why do you say the 300B plate current is 80mA, when the DC voltage across the 10R is 2V?
That would mean the plate current is 2V/10R = 200mA.
Are you actually measuring directly across the 10 ohm resistor? That is necessary.
My bias control here worked fine the whole time.
When you say R10, do you mean R34!!!!
"Bias current is 50 mA on both 300B tubes. I have also tried with 80 mA on both 300B tubes.
whether it is 50mA or 80mA makes no difference to the grid DC voltage is stay on -95V."
That does not seem right. To change the plate current, the DC grid voltage must be changed with the bias control.
"DC voltage across the 10R = 2V"
That means the 300B plate current is 2V/10R = 200mA. That is not right.
See attached schematic, and se where R10 is locate. DO YOU MEAN R34!!!!
That's what the bias control is for.
However your negative supply is much too negative, at -278VDC instead of -150VDC as in your schematic.
Is there a problem with the negative supply circuit? That may account for the problem.
