My bias control here worked fine the whole time.Does the DC bias control now work, and vary the DC voltage at the 300B grid?
Why do you say the 300B plate current is 80mA, when the DC voltage across the 10R is 2V?
That would mean the plate current is 2V/10R = 200mA.
Are you actually measuring directly across the 10 ohm resistor? That is necessary.
When you say R10, do you mean R34!!!!
"Bias current is 50 mA on both 300B tubes. I have also tried with 80 mA on both 300B tubes.
whether it is 50mA or 80mA makes no difference to the grid DC voltage is stay on -95V."
That does not seem right. To change the plate current, the DC grid voltage must be changed with the bias control.
"DC voltage across the 10R = 2V"
That means the 300B plate current is 2V/10R = 200mA. That is not right.
See attached schematic, and se where R10 is locate. DO YOU MEAN R34!!!!"Bias current is 50 mA on both 300B tubes. I have also tried with 80 mA on both 300B tubes.
SORRY, my mistake, i had read 10R as R10.
I have 80 mV across R34/R33
R34/R33 is 100 ohms. That's why I was confused when you wrote 10R
The input stage will not affect the output stage DC biasing, unless the coupling capacitor is bad.
And you say the 300B grid waveform is good, so the input stage is not the problem.
Yes the 300B grid waveform is good, se post 7, the Blue waveform. What about the voltage off the waveform is the okay?
If this is with an 8R load, that may be at the limit of the amplifier output power, stated to be 6-8W.
Reduce the input by half. If the output waveform good now?
it is with an 8k ohms load. The output voltage is only 1v when it start. Post 7 shows the voltage is 3v, it's not even 2W!!!!
Either the 300B tubes are weak or misbiased, since the 300B grid waveform is normal.
As mentioned before, the DC grid voltage seems too negative for the value of the plate current.
How do I raise the grid voltage?Either the 300B tubes are weak or misbiased, since the 300B grid waveform is normal.
That's what the bias control is for.
However your negative supply is much too negative, at -278VDC instead of -150VDC as in your schematic.
Is there a problem with the negative supply circuit? That may account for the problem.
From the 300B data sheet, the grid voltage should be somewhat less negative.
It lists around 60mA at -75V grid. What brand are your tubes?
300b gold electro harmonixFrom the 300B data sheet, the grid voltage should be somewhat less negative.
They are both fine 10.2 ohmsHave you check the ohm value of the 10 ohm resistor? Maybe it is off.
- More Vendors...
- Tubelab
- Need help. Strange sine wave on outputs.
