So my brother wants me to build a subwoofer for him and his college buddies. I am either looking at using this one (MCM Audio Select 15'' Die Cast Professional Woofer - 400W RMS 8ohm | 55-1880 (551880) | MCM Audio Select), a 15" driver with the hd15 horn from speakerplans.com. Or 2 18"(MCM Audio Select 18" Woofer with Paper Cone and Cloth Surround - 300W RMS at 8ohm | 55-2954 (552954) | MCM Audio Select) in a g sub box. So how are these drivers and which setup would you recommend if not something else with a similar price.
Yeah, the hd15 is not a subwoofer at all. I agree: what is this for? And what amplification will it be used with? And crossover? and other speakers? It all needs to work together.
If you look closely the drivers (and freq. response) are next to each project.So my brother wants me to build a subwoofer for him and his college buddies. I am either looking at using this one (MCM Audio Select 15'' Die Cast Professional Woofer - 400W RMS 8ohm | 55-1880 (551880) | MCM Audio Select), a 15" driver with the hd15 horn from speakerplans.com. Or 2 18"(MCM Audio Select 18" Woofer with Paper Cone and Cloth Surround - 300W RMS at 8ohm | 55-2954 (552954) | MCM Audio Select) in a g sub box. So how are these drivers and which setup would you recommend if not something else with a similar price.
Speakerplans.com
Speakerplans.com
Speakerplans.com
RCF L18P300 SpeakerS - RCF 18" L18P300 woofer - RCF L18P300 speakers - RCF L18P300 1600 watt 18" speaker. RCF L18P300 18" woofer and other RCF speakers available here.
Beyma Speakers - Beyma 18LX60 speaker - Beyma 18LX60 1200 watt 18" woofer for all bass applications. Beyma 18LX60 and other Beyma 18" speakers here.
Eminence Kilomax Pro-18A - Eminence Kilomax 18" Speaker - Eminence Speakers - Eminence Kilomax Pro-18A and Kilomax pro-18C 18" speaker. The Eminence Kiolmax Pro-18 is an 8 ohm 1250 watt RMS speaker. Eminence Kilomax Pro-18A and Kilomax pro-18C 18" sp
Fane Colossus speakers - COL18XB Fane Colossus bass 18" 1,000 watt AES subwoofer speaker with extended Xmax of 7.5mm. Fane Colossus 18XB speakers for subwoofer speaker cabinets.
Eminence Speakers - Eminence Omega Pro 18A & 18C speaker. The Eminence Omega Pro 18A & Omega Pro-18C are 18" speakers. Available in 4 or 8 ohms. The Omega Pro-18A is a 800 watts RMS woofer.
