Need help picking design
So my brother wants me to build a subwoofer for him and his college buddies. I am either looking at using this one (MCM Audio Select 15'' Die Cast Professional Woofer - 400W RMS 8ohm | 55-1880 (551880) | MCM Audio Select), a 15" driver with the hd15 horn from speakerplans.com. Or 2 18"(MCM Audio Select 18" Woofer with Paper Cone and Cloth Surround - 300W RMS at 8ohm | 55-2954 (552954) | MCM Audio Select) in a g sub box. So how are these drivers and which setup would you recommend if not something else with a similar price.
If you look closely the drivers (and freq. response) are next to each project.
Speakerplans.com
Speakerplans.com
Speakerplans.com
RCF L18P300 SpeakerS - RCF 18" L18P300 woofer - RCF L18P300 speakers - RCF L18P300 1600 watt 18" speaker. RCF L18P300 18" woofer and other RCF speakers available here.
Beyma Speakers - Beyma 18LX60 speaker - Beyma 18LX60 1200 watt 18" woofer for all bass applications. Beyma 18LX60 and other Beyma 18" speakers here.
Eminence Kilomax Pro-18A - Eminence Kilomax 18" Speaker - Eminence Speakers - Eminence Kilomax Pro-18A and Kilomax pro-18C 18" speaker. The Eminence Kiolmax Pro-18 is an 8 ohm 1250 watt RMS speaker. Eminence Kilomax Pro-18A and Kilomax pro-18C 18" sp
Fane Colossus speakers - COL18XB Fane Colossus bass 18" 1,000 watt AES subwoofer speaker with extended Xmax of 7.5mm. Fane Colossus 18XB speakers for subwoofer speaker cabinets.
Eminence Speakers - Eminence Omega Pro 18A & 18C speaker. The Eminence Omega Pro 18A & Omega Pro-18C are 18" speakers. Available in 4 or 8 ohms. The Omega Pro-18A is a 800 watts RMS woofer.
