need help figuring out what inductor this is..
Method21 Member Joined 2024 2024-03-29 6:57 pm #1 2024-03-29 6:57 pm #1 need help figuring out what inductor this is.. Attachments IMG_3653 (1).jpg 994.9 KB · Views: 46 ••• More options Share vinylkid58 Member Joined 2005 2024-03-29 7:03 pm #2 2024-03-29 7:03 pm #2 Knowing the piece of equipment it's in might be helpful. jeff ••• More options Share rayma Moderator Joined 2011 2024-03-29 7:07 pm #3 2024-03-29 7:07 pm #3 No other identifying markings? If not, you'd have to measure it, or else find a schematic and parts list. ••• More options Share vinylkid58 Member Joined 2005 2024-03-29 7:17 pm #4 2024-03-29 7:17 pm #4 rayma said: or else find a schematic Click to expand... Yeah, that too. ••• More options Share T tauro0221 Member Joined 2008 2024-03-29 7:31 pm #5 2024-03-29 7:31 pm #5 Hi, Looked like a shielded type inductor. ••• More options Share Citizen124032 Member Joined 2022 2024-03-29 7:48 pm #6 2024-03-29 7:48 pm #6 Designator, range, value, size, experience, intuition. Shoot: 100 μH. ••• More options Share Method21 Member Joined 2024 2024-03-29 7:49 pm #7 2024-03-29 7:49 pm #7 on a jl audio amp, I have a fluke 87, not sure how to read inductance on it. ••• More options Share rayma Moderator Joined 2011 2024-03-29 8:14 pm #8 2024-03-29 8:14 pm #8 That Fluke does not measure inductance. Why do you need to do so? ••• More options Share Elvee Member Joined 2006 2024-03-29 8:15 pm #9 2024-03-29 8:15 pm #9 If it doesn't look burnt or damaged, chances are that it is in a good condition. These critters tend to be quite robust ••• More options Share rayma Moderator Joined 2011 2024-03-29 8:16 pm #10 2024-03-29 8:16 pm #10 Yeah, just measure the resistance, and compare with the other similar ones. If not open circuit, it's probably ok. ••• More options Share Method21 Member Joined 2024 2024-03-29 8:19 pm #11 2024-03-29 8:19 pm #11 I need to order some cause the 3 others burnt, I desoldered this one in the pic to measure it to find the right ones to get. ••• More options Share rayma Moderator Joined 2011 2024-03-29 8:24 pm #12 2024-03-29 8:24 pm #12 Measure their DC resistances. Maybe the coating just melted, and they are still functional. Otherwise you need a schematic, or to measure it. ••• More options Share Show hidden low quality content You must log in or register to reply here. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link Home Design & Build Parts Need help Identifying Top Bottom
