Need help for understand mix schematic
I’m quite new on analogue electronics. I found this schematic for a audio line mixer, but I can’t understand something... maybe someone could help me:
1) Why audio signal pass on drain level on t1-t2-t3 but on source level on t4?
2) Why is not present another capacitor to filter dc - ac on output line after t4?
3) why r1 is after t4 and the resistor on the source of t4 has a different value respect the other resistors?
Thank you for your help... I’m try to learning but eletroninc is not so easy...:whazzat:
Its a bit of a strange circuit, however,
Lets start with T4. This is a 'source follower' which is a bit like an emitter follower. It is used as a buffer with voltage gain of a little less than '1'. It enables low impedance loads to be driven.
There should be a cap after T4 (well, spotted 🙂)
Lets take a look at just one of the other stages, T1, T2 or T3. All three are the same. These are configured as amplifying stages and based on a 'common source' configuration.
AMP I.10 – The Common Source Amplifier
R1 is common to all the three input stages in this design (how well that works as a mixer I wouldn't like to say...) and these stages also invert the signal by 180 degrees.
So the 'mixed' signal voltage appears on R1 and is then fed to the buffer stage.
I was going to tell him to use the 5532, if he gets that far.
That circuit is just an example of a more conventional circuit. I'm just trying to show what a simple, conventional layout looks like.
I personally don't think an op amp based 3 channel mixer is a good circuit for a beginner. You need to start with a much simpler circuit.
indeed an interesting schematic.basically it consists of voltage to current converters using a simple fet. rodec once had a dj mixer based on that principle. the advantage over pure resistive mixing and opamp based mixing is that there is a much lower noise contribution of the summing stage, as the summing stage noise is amplified by the number of channels connected, in opamp summers. indeed a simple and clever circuit.
as the fet V->I stage has a high output impedance, the noise contribution is just the sum of the noise of the V/I stages. not bad.
