need help finding a replacement for a JRC 074D quade fet op amp
That should be meant to be an original TL 074, methinks.
What you have is just a low cost source version.
Any quad - low noise FET input OP AM should do, even the venerable LF347.
If you want you may take the occasion to use a more modern ( and less noisy) one like the
OPA4134 .
If its an 14 pin DIP package just go with a TL074. Its a FET input device so I would stick with like for like i.e. don't try and fit an LM324 even though it would probably work. The suggestion above of the OPA4134 would probably be OK (its a good device) but its more current hungry.
