Need advice on crossover
I recommend minimum 2.5Khz and 2.5dB of attenuation for the tweeter. Usually you take a variable L-Pad, adjust to taste and use fixed resistor value to build the final L-Pad. Drivers are very similar to the one that I use in my Arro Clone.
