Hello all , I was wondering if there's any body on this site that can recommend a toggle switch for input switching. I've searched and can't find any results ....it needs to be able to go through a 10mm face place. All the one that I've found are too short. If the bushing was 0.75 inches it would be ok.
I just use a regular bit, but fat, like 1/2 or 9/16", and don't go too deep. Watch the depth; you don' t want the point making the base hole bigger! And then I trim up what I need using a Dremel tool. Luckily it only needs to look good on the front side!
I suppose a spade bit would fit better but those are not made for metal. Realistically such a rebate might best be done with a milling bit but I've never tried that. I have no milling machine or jig but I do have drill press I could try it with.
Carling definitely has some of that size. They are beefier and pricier though. They are usually used on guitar amps
- Need a recommendation for a DPDT toggle switch
