Need a recommendation for a DPDT toggle switch
Hello all , I was wondering if there's any body on this site that can recommend a toggle switch for input switching. I've searched and can't find any results ....it needs to be able to go through a 10mm face place. All the one that I've found are too short. If the bushing was 0.75 inches it would be ok.
I just use a regular bit, but fat, like 1/2 or 9/16", and don't go too deep. Watch the depth; you don' t want the point making the base hole bigger! And then I trim up what I need using a Dremel tool. Luckily it only needs to look good on the front side!
I suppose a spade bit would fit better but those are not made for metal. Realistically such a rebate might best be done with a milling bit but I've never tried that. I have no milling machine or jig but I do have drill press I could try it with.
what tools are involved in drilling a rebate?
My suggestion is look for dpdt toggle switch with M12(NKK) or 15/32"(C&K) bushing thread, they have the body diagonal sizes less 18.3mm.
A M12 (12.4mmx18.8mm DIA.) counter-bore bit will get the job done.
Screenshot 2023-06-26 at 15-07-20 s-l300.jpg (JPEG Image 300 × 300 pixels).png
Screenshot 2023-06-26 at 15-00-18 7215TZQE 7201TCWZQE 7203TZQE 7201TZQE.jpg (WEBP Image 640 × ...png
Screenshot 2023-06-26 at 14-59-45 MFG_M2022B2B1A01.jpg (AVIF Image 640 × 640 pixels) — Scaled ...png
Reactions: audiosteve
