I need about 250W to 350W in 4R mono to power my subwoofer. I am running it with a P3A (about 120W into 4R) and it sounds pretty good, but i need more power when i have built my Linkwitz Transform circuit to take the sub down to 28Hz (-3 dB).
Since it is just for Bass duty, i'm not that concerned about getting 0,000000000001% THD or perfect audiophile sound quality (although i do want that for the rest of my system obviously) and would like suggestions of a DIY amp which is quite easy to build, concidering that my abilities are at the P3A level.
Any suggestions would be great. Thanks all.
Gareth
Gareth
Hi!
Why don't you make the 300W Subwoofer Power Amplifier from Rod Elliot's site?
As you make the P3A, the Project 68 will be no difficult to make, as the basic design is the same.
Read all the text with attention. Use the extra 4 transistors for having no heating problems when getting LOUD!!
Regards,
Pedro Martins
Regards,
Pedro Martins
Well thanks for that. I have actually already designed PCB's for the P68, and i was just wondering if there was maybe anything else out there.
By the way, will MJ15003/4 output transistors work for the driver and output stage? I cannot get the 2SC5200 or 2SA1943 or the MJL21193/4.
The choices I see are:
esp sub amp, leach amp or something form anthony (www.aussieamplifiers.com)..
Decided
I think i'm gonna go with the ESP sub amp. It is simple and similar to the P3A's i've already built. Now i just need to find a suitable heatsink in this place...
Cheers
Gareth
Cheers
Gareth
Heatsinks in SA
Hi Gareth,
I have access to alluminum extrusions, and one in particular suitable for P68, however they only sell it in 6 metre lengths. Please reply to the Email I sent and we can discuss possibly buying a length and sharing the cost.
Where in RSA are you?
DieterD
Hi Gareth,
DieterD
- Need 250 to 350W into 4R
