If there is a "curse word" in a URL, the forum will break the link.
Here is an example:
https://www.bunstersworldwide.com/products/bunsters-****-the-bed-hot-sauce-12-10-heat
The word that is censored is another word for poo.
It's an Australian hot sauce, and this forum is based in Australia, right? 🙂
Here is an example:
Lol, it looks about as Australian as Outback Steakhouse 😀
Seriously though, the link is failing because it was altered, but it was done in a way which I don't believe is consistent with the autocensor here.
Ok. But the word "****" is in the URL. How is that not an error?
Also dare I say, **** is not a "bad word" in North America anymore. Neither is Fart.
At the risk of running into laws of the forum, maybe it's time to re-visit the language laws on this site?
Carlin Seven words test of censorship:
**** **** **** **** cocksucker motherfucker tits
But is it?Ok. But the word "****" is in the URL. How is that not an error?
The link is clickable and is a different colour to the text (typically blue/purple). This means the autocensor has not touched it. If the autocensor had changed it, the link would be in regular black text and would not be clickable. [EG:- https://www.bunstersworldwide.com/products/bunsters-****-the-bed-hot-sauce-12-10-heat]
No, this appears to have been entered into the post after already being changed to asterisks.
All in the name of science 😉Also, please don't ban me because I pointed out flaws in the censoring?
test
https://****-****-damn.com
Allen is right, base don that experiment. The censor only changes what appears in th forum, if you go to edit it is still there (allen can confirm for you). In your URL the **** has been replaced with **** even in edit mode. That strongly suggests it is not the nanny censor in action.
dave
dave
I can't duplicate the highlight. However between kodabmx, a well-known and valued human member; and an opaque ill-tempered autocensor buried too deep in code for causal inspection, I know who/what I would blame first.This means the autocensor has not touched it.
IMHO, URLs should be exempted. Apparently they are, with exceptions. Like the twit filter which inconsistently blocks twits. I can't see a twit-started thread, but I can see replies to it in my Alerts, which is more spooky.
May I suggest a method to test this yourself. Post the word in question here in this thread and it will come up as asterisks. Now go in and edit your post and you will see the word in all its glory.
Since kodabmx can edit the first post here (any thread starter can), he will see that the word was replaced before the post was submitted. (I see you posted at the same time as Dave, who said the same.)
If I use **** in running text, if that word is offensive, then it should be censored.
But if www.hotshit.com has great resistors, the censor works against us.
And.... now it is working about as I would wish. The URL is not corrupted.
No, I did not do the go-back-and-edit path.
I'll attempt again:
Quotes didn't help but editing and saving makes it a broken link instead of text.
Like this:
Like this:
No, I'm just pasting the URL. It just comes up as plain text with **** instead of s h i t and not a clickable URL, but editing and saving replaces it with a clickable URL that also doesn't work.
The expected result is the site and URL in this pic.
- Site
- Forum Problems & Feedback
- Nanny Filter breaks URL links
