NAD 3020A - Modern Replacement Transistors - HELP PLEASE
Hi there
I would like a definitive list for placement transistors for a NAD 3020A amplifier. The transistors needed are the following:
2N3055 & 2N2955
2N6551 & 2N6554
Thank you in advance.
I accidentally destroyed my NADs right channel due to a wrong connection in a speaker crossover... very mad at myself. :nownow:
NAD 3020 and later variants had a few driver complements.
Hitachi/Renesas 2SB649A, 2SD66A were also used.
The 3055/2955 power complements would have to be the longest runnning, most common and cheapest on the planet.
Deltavektor, you haven't said what is available to you. Is there a repair shop with any transistor parts nearby?
From what I know there is a rs electronics branch or used to be in bryanstan, I ordered plenty parts through them when I was still in SA. Also there is philtron in Pretoria or communica in JHB, they will happily post parts to you, if you looking for japanese transistors, theres apon electronics in JHB.
In Nelspruit there used to be a specialised hi fi shop, with highend equipment, they sold specialized caps as well and could probably help you out, they might still be around too, Ill look it up.
