What a marathon. Did you ever get it running? I have a 2200 with blown left outputs, but no other signs of damage. I am hoping I can get it figured out. I do plan on a complete recap very soon once I figure out whether it will run or not. Do you know if I remove the PS cable from the left channel board, will the remainder power up if it is OK?
Thanks,
Mark
Thanks,
Mark
Thanks for the reply! That is my course of action. Physically everything in this amp looks ok, but the outputs are shorted. I am in the process of checking backwards in the print to make sure everything else measures OK. Would you happen to know how to check the two adjustments on the board, once I do get it running? I will be using a DIM bulb setup to bring it back up.
Thanks,
Mark
Thanks,
Mark
- NAD 2200 repair
