Has anyone compleated the 1000w version ??
Lars,
You said long ago that you were going to post another version with balanced inputs and protection ckt etc
We are waiting !!!
Cheers
Lars,
We are waiting !!!
Cheers
Nexus,
Try Class-T amplifier. If you're interested, please go to this website and find out more.
www.tripath.com
Good luck.
www.tripath.com
Good luck.
Lars,
We are waiting !!!
Cheers
Lars,
We are waiting !!!
Cheers
Rajeev,
Yes, they are all good in both hi-fi and power. I'm currently working on the TA3020, particularly on PCB Design for my prototype. If you want more power, TA0105 will do 500W/ch. This is a link
http://www.tripath.com/audio.htm
Thanks bvp9223 ,
Could I know the price of the 300w & 500w versions also where can the be bought from in the USA if only one or two pcs are required
Hello,
Thanks for the link , these class T amps seem to be same as class D and very interesting . Please let me know of the progress of your amp with this driver ic , also can they be used in bridge mode ?
What about the power supply , can a normal supply be used ?
With Best Wishes
Rajeev
systems_rajeev@rediffmail.com
With Best Wishes
Rajeev
Reply
Hi Rajeev,
Tripath has an office in Bangalore itself, contact them on their website and they will give a CD and also arrange evaluation kits if you insist.
I am saying this because they have contacted me last year.
regards,
kanwar
Hi Rajeev,
regards,
kanwar
What is the price of the 300w driver ic , it gives 1000w at 4ohms in bridge , and class T is what they claim class AB sound in class D
,is it that good ???
Re: Zeta PCB
Hello Lars,
are you still working on the Zeta? 😉
Well, I'm coming up with a board design for a single output pair. I plan to make it expandable (multiple output fets without a complete redesign of the layout).
You explicitly state that the Zeta schematic may be distributed freely for non-commercial use, but You never said anything about actual PCB layouts.
So, is it okay for you to see board designs discussed on the forums?
Kind help of yours with questions that might arise would be great, as I'm not an engineer 😉
Sebastian
Hello Lars,
Sebastian
Lars,
We are waiting !!!
Cheers
Lars,
We are waiting !!!
Cheers
Reply
hi Rajeev saab,
I think Mr.LC_man is busy in some sort of important task , maybe R&D in protection and balanced inputs.
Hope for earliest solution available to you.
kanwar
rajeev luthra said:Has anyone compleated the 1000w version ??
Lars,
We are waiting !!!
Cheers
hi Rajeev saab,
kanwar
Dear kanwar,
I am sure Lars is a busy man. As far as protection is concerned we definately had a look the way yours went.
Here at least we have a proven design from a commercial man who delivers to the DIY community. Still looking forward to your great amp schematics and topologies and ah yes the site too????
Still being in India do not have a decent dealer address for the great stallions or brochure I am sure the other country diyers are having them its just my shortcomings.
Hoefully in far future I may be blessed with the great sound of the workhorse.
Rahul
Rahul
Ampman,
I am looking forward for the pcb and design you were to send me in mid Dec last ,
Regards ,
Rajeev
Regards ,
Rajeev
zeta amp!!!
Hi Lars!!!!
where are you , and your zeta amp is not to be seen at your www.lcaudio.com website.
I was almost finished on my Pcb work but waiting for your changes!!!
thanks
Arasuk
Hi Lars!!!!
thanks
Arasuk
Hi
Nice to see a post here after so many days ,
I am sure that now Lars will finally come with the new version sooon , and that will be the ultimate .
Hello Lars,
to my dissapointment, I still have not received any pcb from you.
Are you still working on it? or there something wrong with the design?
Best Regards:
Nexus
Best Regards:
Nexus
Zeta Amplifier Heatsink Components
Ok, I have seen mixed feedback on what devices need to be mounted on the heatsink aside from the irfp250's. Lars, could you run through the specific list?
Also, anyone have a good method of mounting a TO-92 package to the heatsink?
Thank you so much, this question is bothering me badly!
Joined 2002
bobo1on1 said:Here is my amplifier I designed a while ago, I didn't build it yet but it should work 😉
I used local feedback to make the mosfets behave somewhat like normal transistors, at least for the voltage they need to turn on.
R6, R7 and R13 are there to stop the transistors from blowing up when the fets run out of voltage.
The reason I designed this amp is because I want to make 4 bi-amped active loudspeakers and I can get these fets for 10 eurocents each 😎
The only downside is they are 55 volts 🙁 but 75 amps 😀
I like this. Did you get it built yet. ? Can i make a board for this ? Please email me.. jason..
- N-Channel mosfet amplifier schematic needed
