Have Samsung S27D850T monitor that doesn't turn on when cold. This might not be the forum, but people here know this stuff.
I replaced small small caps, then I saw this:
YouTube
Then figured it's worth a shot to replace: N-Chanel 600V 12A KF12N60.
Got 3-pin ones (couldn't find 2-pin), now I really don't know what to do 😕
Here's the parts I have :
https://www.onsemi.com/pub/Collateral/FDPF12N60NZ-D.pdf
YouTube
This is a MOSFET and the middle pin is connected to the tab. So if the tab is connected, you don't need to connect the middle pin.
Jan
Jan
Jan
That's kind of what I was hoping for, but the tab has heat sink compound on it, I don't know if it conducts electricity or if the middle tab is not needed at all.
I was just looking at a random TV board and I noticed some MOSFET's have 3-pins and some have 2-pins, but all are connected to heat sinks.
I replaced the MOSFET and monitor blew up
The 2-pin was a N1106.
I did not change that one, well I soldered it back in, since I had no replacement.
The 3-pin seemed to be correct.
Only difference I saw in the 3-pin I replaced, is that the original had a plastic coated tab and the one I put in was bare metal.
I saw sparks and then smoke, then no worky 😀
The plastic tab isolates it from the grounded metal of the heatsink....
Are you sure the two pin thing is a MOSFET, and not a diode which would have two pins.
Jan
N1106 was two pin, I told it off and then soldered it back on.
Then the other "thing" was 3-pin ; I replaced that one with this:
It had the same specs I think, but the ON SEMI I got was bare metal.
I saw sparks, heard noise and then smelled smoke.
That was it for the monitor.
- Design & Build
- Parts
- N-Chanel 600V 12A KF12N60 -- need 2-pin, but I ordered it and it is 3-pin ???
