What size screw is used to mount the heat sink to the Cadock MP915 resistor?
no luck at Mouser
The hole in the resistor is 2.39mm +/-0.1mm so a Metric M2 screw would work. I used a 2-56 English screw and it fits fine.
Just finished assembling one board.
Cant wait to hear what these sound like. I own a pair of twisted audio Rev C and I already think those sound great.
Uploaded with ImageShack.us
Hurrah, hurrah Uriah,
today the package arrived.
Thank you very much for the nice work you have put into it!
I will see how far I will get this weekend. Problem is it is beautiful weather, something relatively rare in this country.
I have to enjoy that as well!
Cheers
Michiel
Cheers
Michiel
What heat sink is on the Cadock MP915, How is it attached?
I used these heatsink for TO-220
10 Units Heat Sinks Insulation Bushing And Film TO-220 - eBay (item 390201527722 end time Jun-26-10 05:13:33 PDT)
The Caddock is screwed onto the heatsink. The screw is a bit big for the hole but with a bit of sanding it fit.
The heatsink fits very well in the provided space
This board has 3 ac inputs, AC1, AC2 ans PGND.
can I use a dual 24/25vac transformer, if I do what goes to PGND?
Or do I need to series wire a 12X12 and use the tie as png?
Your schematic is correct but secondaries value is wrong, you need 24V secondaries --> -24 0 +24V ---> 48V swing
I have 24vac secondaries if they are wired in series = 48vac, we want 24vac correc?
wired Parallel = 24vac more va correct?
Where does the PGND wire com from?
Can you draw a wiring diagram showing PGRD?
But you didn't replied my last question, does you trafo has any picture on it?
Here is the data sheet
- Group Buys
- MyRef_C with Ultimate BOM
