While some have reported fine results with rather meager sinks I am also in the camp that too much is never enough when it comes to heat sinks. A good read on sizing these beasts is the article by Rod Elliott http://sound.westhost.com/heatsinks.htmAndrewT said:at least twice what National specify in the datasheet.
I can tell you that the heatsink you see in http://picasaweb.google.com/schro20/FinalBuildOfRevCFromKit#5296425580447681922 is far too small. It got hot enough that I could barely put my finger on it for more than a few seconds without deep meditative breathing! (I ran the amp at full tilt for half an hour) Technically that's still ok (say 50 C above ambient), but the chip performs better and lives longer if you don't go to such extremes.
Uriah (who is offline for a few days) has had good experiences with CPU coolers. I haven't tried that myself, so I can't comment.
peter
if that sink that schro says is too small then believe him.
I'd guess it is about 4C/W.
Table, on page10, shows ~60Vdc for an 8ohms speaker. This will run the chip very hot.
Adopting an 8C/W design, but using a double size sink (4C/W) would be ~ 46Vdc for an 8ohm speaker.
I suspect Schro used a lot more than +-23Vdc for his supply.
Correct. When I did the heat test I oriented it sideways. I drove my large FE207e Metronomes pretty loud. Now these babies are quite efficient, so they don't actually stress the amp that much... One thing I still need to do and haven't is to check on any high frequency oscillations since they could explain seeing far more heat than one "hears." Though this design is supposed to be quite good at not burning through a lot of power outside the audible spectrum.troystg said:The heatsink in your picture would probably be fine if the fins were vertically oriented. Efficiency is LESS THAN HALF with horizontal orientation.
Peter
schro20 said:One thing I still need to do and haven't is to check on any high frequency oscillations since they could explain seeing far more heat than one "hears." Though this design is supposed to be quite good at not burning through a lot of power outside the audible spectrum.
Peter
I'm curious to hear about your results. My next project is a NOS mod to an old Magnavox TDA1541-based cd player. Removing the OS has the potential to drive some amps into HF oscillation or burn up a lot of power.
I used a 25-0-25VAC toroid which is rated at 300VA. In practice that means that I was actually seeing 27-0-27VAC. Multiply by sqrt(2) and you get some pretty beefy DC on the rails...AndrewT said:I'd guess it is about 4C/W.
BTW, anybody who says that bigger toroids give them better bass first has to show me that they are running with the same *actual* voltage. Most of the time one only draws a small fraction of the total wattage and hence operates most of the time in the higher voltage region that a larger toroid will be designed for...
I have heard big differences in bass delivery, but I suspect most of it is due to simply running at effectively a higher voltage. But I would be interested to hear of any comparisons *at the same operating voltage* and higher wattage. Anyway, a different argument then heat sink size.
Did I mention that ApexJR has some nice and BIG heatsinks? Very good prices too. I schlepped off with some serious metal for my final build!
Talk to Steve of ApexJR. Not everything he has in big metal is on the website.
peter
music2diy4 said:I am really disappointed that I missed out on this group buy. Does anyone out there have any extra boards or kits available? If not, is there a reasonable possibility that another group buy round could be initiated sometime in the next few months?
See his last sentence!
http://www.diyaudio.com/forums/showthread.php?postid=1758777#post1758777
troystg said:
Maybe we can get Dario to come up with the ultimate component selection... Dario? You game? (Just doing a dare here... I am not about to do another one; this was fun, don't get me wrong, but I have so many other things I want to try right now; several cabinets that await finishing, several more amps that want to be built and compared, etc. etc. etc.)
Peter
schro20 said:Maybe we can get Dario to come up with the ultimate component selection... Dario? You game?
The component selection of the GB is quite good and is a good balance of performance vs. cost, IMHO.
Adding some bucks it could be upgraded, of course...
I think that I wouldn't be able to have the patience you and Uriah had managing the GB.
Also I don't have enough knowledge to modify Eagle files too...
But for support, beta-testing and similar I could be in.
Based on your research I'm going to pull out all the AVX's and put in some Vishay MKP's and bypass the big caps with MKP's.
marc brown said:Based on your research I'm going to pull out all the AVX's and put in some Vishay MKP's and bypass the big caps with MKP's.
Hello Marc,
pay attention to the fact that my tests was for a signal path bypass cap, AVXs could be good in PS...
I suggest you to use sockets too, it could be that Vishays MKP aren't any better... I've had some surprises too...
This is mostly Brian's work. Whenever I tried to deviate from his recommendation to get a better price I soon returned to his suggestion (or an equivalent) realizing just how well the trade-off between price and performance was done by him. Kudos to Brian!ClaveFremen said:The component selection of the GB is quite good and is a good balance of performance vs. cost, IMHO.
Peter
One important word of caution. When talking of parts just giving the company name doesn't tell the story. One has to be careful to specify the exact series the part comes from. I discovered that when spec'ing parts. In particular because some firms have been bought up by others and you can get some real surprises by that.ClaveFremen said:pay attention to the fact that my tests was for a signal path bypass cap, AVXs could be good in PS...
peter
TOROIDS
I want to let you guys know I now have in stock
some new toroids:
24V - 0 - 24V 200 Va at $ 22.00 each
Steve @ Apex Jr.
steve.apexjr@prodigy.net
some new toroids:
Steve @ Apex Jr.
madisonears said:Does anyone have a spare board they would like to sell?
Peace,
Tom E
Not just the board, but I have a complete kit that I am not going to build, if anyone is interested. - Pat
- Group Buys
- my_ref revC group buy (Mauro Penasa LM3886 design)
