Hi Ivan
I use a DCB1 with the FE which sounds clearer and cleaner than the standard B1 to my ears and in my set up.(I have both B1's)
Here is the link.
http://www.diyaudio.com/forums/analog-line-level/171715-salas-hotrodded-blue-dcb1-build.html
Or I use no pre and go directly from the output of my Buffalo DAC with its internal volume control.
Here is the link.
I will build subbu dac which will be followed by JG filter buffer
If no satifaction dcb1 is on top of the list too
Good choice
I have a 9023 DAC with the same filter/buffer and nothing wrong with that set up driving the Volume pot of a DCB1.🙂
sounds nice
If you were doing a survey - Uriah's Lighter Note LDR is my top electronic attenuator for a no-gain solution.
The JC-2 clone from eBay provides all the push I need for higher volumes. I does add just a bit of its own color but sounds better than a Carver C2 and anything else I have owned.
I haven't built or heard a B1 of any flavor yet, so I can't make a comparison.
I have ldr integrated with input selector. It is not that asvanced like Uriah own one but sounds good indeed. I never ever needed till now push amps hard enough so my (unity gain ?) Pre is good.
I just noticed how every single part we add change sound.
I cannot call myself extremely sensitive person but I do hear differences in sound my wife does not.
So many dcb1 versions out there. I need no input selector one , understand its an older version?
Mesmerize has the 6way input selector.
Hypnotize is the basic DCB1.
They are available from the Forum shop.
There are no others. Only variations in value for those that feel the need to make them run hot.
Go and read the DCB1 Thread, it's all in there.
Good morning to everyone.
I put another pre (LDR based) in front of the FE.
Used to have B1 with obbligato and russian pio caps. Been rolling caps for some time there and sound was changing in all directions: from lean to full, from congested to open. All in all I could no find right balance of the caps and audible picture I like 100%.
So now it is LDR. Everything is nice, clear and bass is incredible. But somehow 3d imaging front to back placement of instruments shrunk to the point I hear just stereo.
Question: if I d opt for c13 roll which cap would give tiny bit more sparkle and open imaging ?
I ll do dac soon with buffer on output so it could help, but would like to try to tune cap just out of curiosity.
I ll start from russian k71-4 which I have on hands.
I would like to ask if you combine two or more caps, is there room to improve the sound?
Will do Andrew, sorry for ot.
Probably people here could say more about caps but they indeed as dd flavour to the sound.
Hi All
Some further comments on Pre’s
I’ve had a few days to spare and have used them to explore my pre amp collection connected to the MYREF FE.
My initial preference was for the DCB1 but with a longer listening session (sessions) my opinion has changed a little.
This sound just wonderful
http://www.hificollective.co.uk/kits/passivetvc_description.html
And plays into the strengths of the FE very well.😎
Huge 3D soundstage and great dynamics with a natural tonal balance.
I’VE used the Glasshouse AVC plenty with my Tube builds but kind of forgot about it now that I’m more in SS land. But this is a really good sounding unit with great top to bottom clarity which edges the DCB1 just a little in my set up.(and of course is a little more expensive)
Incredible Slam, focus and vocal projection.
I must try my C core version next🙂
Whilst waiting for my components to arrive I had a read through the original MYREF thread and remember someone describing the original as a ‘’Budget amp’’.
That must have been a joke
The FE is sounding fantastic
The My_Ref, even in its original form, has never been a 'budget amp' (soundwise).
People that wrote so probably have ruined it with a really poor component selection.
The FE, though, it's not a small improvement over the original My_Ref.
Hi Dario
Yes or wrote without listening which does happen🙁 making comments only on what they think the amp sounds like.
My build has taken a little time to really settle down.
Sometimes even going backward a little but you mentioned that and I really appreciate your honesty with regard to burn in and what to expect.
it helped
I’ve used Black Gates plenty and expect to wait for the goodness to happen but that Isotek cd you mentioned really helped to ''speed things up a little''.
Your FE edition of the MYREF is sounding very good and a real audio gem😎
I’m glad that I built this amp.🙂
Which is why my name is down for the 3rd GB.
It’s super quality sound wise and well thought out.
Well done
Well done
Shoom it is much more expensive 🙂
I d love to try it though
Hi Ivan
He sells the transformers separately so just add your own box and switch which saves a little cash.
I did it that way and then bought the nice little box that goes with them after I’d assessed the sound.
The Glasshouse units are good and I’ve read made by Prometheus but to a slightly different recipe.
I’ve seen some TVC on eBay but I’ve not heard any so can’t say on SQ.
I’ve thought about trying some but those TVC should be wound to tight tolerances so I worried a little about quality.
Anyone heard any of those Chinese TVC?
Don't want to wander too far off topic, but there is a new version of the JC-2 pre that I use. E bay no longer allows direct links to items, so if you are interested put the following in your browser address or search bar. It has three discrete pieces.
Should be a nice match for the FE
Modular stereo preamplifier JC-2 kit premium parts ultimate performance
Hi Bob
Yes I have one of those kits on order for use with another amp (also JC-80 boards) but it's hard to see how the FE needs gain.
seems pretty sensitive to me.
Jim's stuff is usually ok so it should be an interesting start point.😎
Hi Bob,
That's the exact kit I was referring to on your old JC-2 thread. I have this preamp for 3 months now and all I can say is it is really good. Nothing to compare to the older JC-2. Actually, this one is supposed to be the original circuit. Coupling caps quality are really important here.
Ciao!
Do
Ciao!
Do
- Chip Amps
- My_Ref Fremen Edition - Build thread and tutorial
