Please have a look at this and tell me what you think.
It is designed to utilize Carlos' Snubberized PS.
Cheers!
Cheers!
Helu Russ, do you have Eagle in your "Autostart"?
I'm sure it will work, and I'm also sure that you already have etch it?
On my board (wich is a 99% BrianGT copy, so thanks/sorry Brian
) I added snubberz before the big cap.
http://www.ettnet.se/~tobias/diy/lm3886/3886.png
Another (big)
http://www.ettnet.se/~tobias/diy/lm3886/lm3886opabuf.png
Keep spitting 'em out...
Another (big)
tobias_svensk said:Helu Russ, do you have Eagle in your "Autostart"?![]()
Ah autostart now there an idea!
Nice work Tobias!
Thanks for the reassurance.
asgorath said:could you please post the eagle files?
I will let this think loose into the wild only after I have tested it.
Update
OK, I tweaked the layout a little and etched the boards. I will build the amp tonight. Here is the latest layout:
richie00boy said:Nice, but no zobel option?![]()
I have thought about adding that. But, my speakers already have zobels in them, so I figured why have two zobels in the output?
The point of a Zobel network on the amp's output is to provide a low impedance termination for high frequencies, which increases stability. A Zobel in a speaker can't do that because it's seen through the resistance+inductance of the speaker cable.
Of course you might not need a Zobel, but it can't hurt to leave room for one, just in case.
Mr Evil said:The point of a Zobel network on the amp's output is to provide a low impedance termination for high frequencies, which increases stability. A Zobel in a speaker can't do that because it's seen through the resistance+inductance of the speaker cable.
Yeah, I understand they have different roles, but I thought I read somewhere that they could interact. Still, I suppose putting places for the components is a good idea, and it can't hurt as you can omit them.
Re: Update
The board looks good. It certainly is more tricky working with 1 layer.
Do you not need to tie pin 5 to V+? I haven't tried it without it, but I guess you could put a short circuit jumper on the chip package to tie these pins together to V+.
Best of luck with the amp,
Brian
Russ White said:OK, I tweaked the layout a little and etched the boards. I will build the amp tonight. Here is the latest layout:
Brian
Hmmmmmm.... In the library I have pin 5 is not connected to V+!
I will have to fix that.
Here we go.
Here we go.
How is this?
Now with zobel. I think is it.
- Chip Amps
- My tiny single sided LM3886 PCB layout. :)
