My Take on X-BOSOZ
Russ White said:
One thing I had considered (but I think I may actually do something differen now) is simply mounting the fets to each side of the case. So you would have one channel on one side and the other on the other with the two PS in the middle.
That's my idea but i was thinking about laying the boards flat wit the fet's flat with a nice piece of copper bar to help dissipate the heat 😛
PICS!!
So, Russ sent me a couple circuit boards:
I test fit all the components from the kit, and everything fits perfectly.
I had some time last night to build up a power supply board with kit parts (everything you see is in the kit). Here are the pics...
I am still matching FETs and building up the kits, so I hope to start shipping next week some time. I have been sick for a few days, that that's been a small delay. Anyway, we will definitelt meet or beat the Jan30 ship date.
Also, the Dales shoudl be in in the next few days, so I'll be posting something on the site for those who are interested in that upgrade.
I am also thinking of buying either Amveco or Avel tiny torroids (18x2, dual primaries) to sell to power these. More on that in the next few days.
Haha your perfboard circuits look better than any perfboard circuits I have ever built. 🙂
Thanks so much Terry for all your help.:up:
And Steen thank you too for your support and your protyping! 😀
One techncal question for you. Given zener values of 75V and 25V what is the maximum secondary voltage one would reasonably use?
I was thinking 56V(2x28) but those are harder to find then 60V(2x30). And 18V for the negative rail(2x9).
There is no technical limit for the secondaries, just practical limits. The limit is governed by the power dissipation that the regulating transistors must deal with. For a 60V secondary, if using one powersupply to supply both channels, the +ve regulator FET will be dissipating about 2.5W, so given the heatsinks you are using, it shouldn't be a problem.
60V(AC) x sqrt(2) ~= 85V(DC) pre-regulator
85V-70V = 15V drop across +ve regulator FET
0.08A bias x 2 channels = 0.160A current through +ve regulator FET
15V x 0.16A = 2.4W dissipation.
Calculation is much the same for the -ve FET.
Does this answer your question?
One quick observation, an 18V for the negative secondary only gives ~25VDC, which is a little on the shy side. I'd try to find something between 20V and 24V for the negative secondary, with a minimum limit of 18.5V.
I don't think Brian's very interested in this at all :clown:
With those Jensen Caps, here's what the bandwidth will be.
