some pics from the sub i just built. It's in the testing phase right now so no paint or finish shots.
Oh yeah, you'll notice i didn't use the first set of bottom curve I made but since the process was the same i didn't bother with pics.
it's for a Dayton Audio RSS315HF-4 12" Reference HF Subwoofer 4 Ohm High Fidelity Reference Series in a 6ft^3 box tuned to 15Hz. after about two hours run in I took it for a spin, It is a beast. 12down is at ~12Hz 😀 and in room 2db down at 20Hz, at 105db/25Hz the port makes no extraneous noise, nada.
pt 2
Very Cool!
I'll be tuned in to hear about your results as I am very interested in how that driver performs.
So far the specs I have seen so far are excelent!
jer 🙂
jer 🙂
Very Impressive,
Excellent build quality, well done, How many watts are you powering it with? are you bothering with a HPF?
for now 300w, HP active at 16Hz. I deactivated the HP and there was no real improvement so for protection turned it back on. i love MiniDSP 🙂
Cool, Can you get some THD measurements or FFT charts for various levels and frequency sweep's?
jer 🙂
jer 🙂
Camaudio, Yes it's birch. the inside of the port is lined with 4mm rubber (pond liner)
Neodan, no, it took 1.5 sheets
geraldfryjr, patience my good man. 😀
Here's the in room. I'll take it outside tomorrow. 😛
the wife is home I had to keep it down 😀
edit: the graph with the two separate plots are near-field (6") in 2db increments.
It's raining on my parade today. Electronics problems (clipping somewhere in the signal path, time to get out the scope) and it rained, literally. 🙁
WoW, Very cool !!!
Thank you,for taking the time to show us those tests. 🙂
I am definitely going to have too get four of those drivers!!
Thanks Again !!!
jer 🙂
Thanks Again !!!
jer 🙂
- Subwoofers
- my "little" build
