my latest amplifer
I thought I'd share my latest almost finnished amp with all.
It's basicly a p3a front-end with constant current instead of the boot strap and then into a tip122 quasi output but at a lower voltage so I could use 2n390X throught out.
It was made with parts on hand so some values are less then optimum like the 33p cap in the front-end should of been larger.
Revision
Here's the reivsed.
I like to to keep simple things simple, but Millwood if your reading, do you think by using a shared ccs in the df stage I will be introducing more noise by the flucutuations caused by the vas, than I can wrinkle out by the increased gain of the new df's ccs vs negative feedback?
I have one made already, I'll make another with the revisions and see which looks good.
What about the g19er? Does that affect the other g19er? I just made a 10,000 watt amp and it really rocks. If you want the schematics no problem.
It has 50 transisters in a row! It gets very hot so I have a house fan cooling it.:hot:
subwo1 said:
How 'bout the possibility of using the TIP127 as the complement to the TIP122? Then the circuit should have more stability and you can omit Q8 and Q9.🙂 One idea to facilitate serious circuit design while avoiding a lot of need to deal with lower level interaction with circuit programs is to try mc7demo.
hEY dO U KNOW THAT qUASI cOMPLEMENTARY IS THE sTAGE WHICH IS PREFERRED MOSTLY IN pROFESSIONAL aUDIO BECAUSE OF ITS sYMMETRIC CURRENT CONSUMPTION OF BOTH RAILS AND THE CURRENT DRIVE IS MORE ROBUST AND THE SOUND QUALITY HAS SOME MORE EXERTING PRESSURE IN TERMS OF COMPLEMENTARY DESIGNS.
rEGARDS
aMpMAn
