1uF is the max recommended for coupling cap. Somewhere George(Tubelab) wrote a terrific post on why that is. IIRC it had to do with the corner frequency, saturation of the cap itself and time it takes to "recover" if I am describing it correctly. Also I think he went into why guitar amps tend to be 0.22uF or less and why hi-fi amps tend to be between 0.22 and 1.0uF.
I will try and dig it up...
JACKPOT!!!
JACKPOT!!!
Thank You for all the help. I think the post is in:
http://www.diyaudio.com/forums/tubelab/177194-tubelab-se-coupling-capacitors.html
I will now reduce my output cap to 1uF. I expect all will be well.
Alright, I'm going to change my input tubes from 6CG7's to 6DJ8's, I need a little more gain.
The manual shows the R10 value but that looks to be in the output section.
If I look at the input section the only value that looks to change would be the R3 & R4 but the voltage suggested for R3 & R4 is at 150V.
I am running @ 290V w/ 7.3 mA to my 6CG7's, @ 300V the chart shows 8mA to the 6DJ8 but that is set by R10 which is in the output section.
Will my higher voltage (290 vs 150) @ the R3&4 change the values needed for R3&4?
Should I just plug them in and hope for the best?
There doesn't seem to be much listed for changes in the input tubes.
The short of it is that I want to run a 6DJ8 @ 290V on the input of my glassware Aikido 9-Pin All in One.
check out this post for an explanation of heater to cathode voltage.
But with 300v b+ and heaters at b+/4 or 75v above ground you will probably be OK.
You might want to consider trying to drop b+ to 250 or so.
- Tubes / Valves
- My First Tube Preamp
