My F4 Build
Joined 2011
Maybe Some New Progress
Well, my replacement Mouser order is here.
They were out of the Panasonic .47Ω 3W so I had to settle for the KOA's as the replacement.
I have just finished building a 4wire measuring board for matching my .47Ω resistors, a bit of a pain in the *** but worth it.
I have matched my .47's and my 220µF's, I don't know if it's really necessary but I suppose it couldn't hurt.
Now I will work on getting the Binding Posts installed.
Joined 2011
Boards Finished
I have both boards completed, It was a bit of a pain to get the old fake J-Fets out of there but the new ones from Spencer are in now.
I ordered a few TO-92 heatsinks with my last Mouser order, I don't know if they will help any but they probably can't hurt.
I also bypassed the 220µF FM's with some 10nF 1837 MKP's, also figured it couldn't hurt.
Now will be a bit of a wait before I will have the P/S done so I will be focusing on the chassis in the mean time.
Joined 2011
Would it be ok if 2 of my output FET's per channel were hooked up with wires instead of soldered through the holes?
Or should I just hook them all up with wires in that case?
There is some mounting hardware on my heatsinks that is in the way of the inner two FET's.
Joined 2011
Things are going pretty well.
My F4 is on hold for now until funding for the P/S frees up.
I understand the AnTek facility caught fire so I will be waiting a bit until their production comes back.
After the P/S is completed I will be able to complete this build.
I am still planning on P2P wiring on the P/S, there is no sense using a PCB for a couple of rectifiers and caps.
Joined 2011
Caps will Hot Glue upside down with resistors bridging them, the rectifiers will be mounted to the chassis bottom.
That should keep it clean and allow for "flexible" placement if need be.
I will build the P/S to look just as it shows on the F4 users manual.
I'm debating on the 200VA or 300VA toroid though.
Antek has the AS-3218 in stock right now for $41 but the AS-2218 is out of stock @$32.
Joined 2011
Alright, The ball is rolling once again.
I was thinking since I will be force cooling this amp should I use a 400VA transformer so I can have more overhead on the bias?
Or will the 300VA Antek be suitable up to 400mV bias?
I know the build guide shows 300mV being the "Sweet Spot" but with forced cooling I should have more bias ability.
I will be ordering all the P/S parts in the next few hours, HAPPY FATHERS DAY TO ME!!!!
6L6
Moderator
Joined 2010
400mv =.4
Across a .47ohm is (.4V/.47R) = 0.85A per device,
With 23V rails .85*23 = 19.6Watts per device.
19.6*12 = 234W of standing bias. That's quite a bit to ask from a 300VA transformer. (And awfully hot as well...)
Use a 400VA.
Also, the distortion gains when biased past 300mV were very small compared to the current required. However, if you have the power and heatsinks, by all means try it.
