Tnx!
Here I have started gluing the spacers (20x2mm PVC) :
Using diluted contact cement - smells ....
/R
/R
The project is a bit on hold - have to do some glue tests !
I've got hold of epoxy used for gluing planes and want to se how well it bonds to Mylar.
I have contact cement that works fine, but then I only have abt. 0.2s to get the stators aligned right!
All stators are now paited och have 3-layers of polyester or laquer on them.
Have some more PVC-spacers to glue, but after that it's time for the Mylar and a first smoke test!
/R
/R
I would be interested in seeing if possible , Info on how you plan to do your power supply and x-over if any ....
regards,
regards,
I have built a couple of test EHTs.
One using a 555 timer and then a 4-5x voltage multiplier and one using standard traformers and multiplierstages.
Will post pictures when I have a final version!
The PVC is from a local dealer. Comes in 1000x2000mm sheets.
I have cut it into strips 20 & 10mm wide.
Using 2mm for the treble panels and 1.5mm for the tweeter ( no 1mm in stock)
Have not decided how I will construct the X-over yet, but I think it will be active!
/R
/R
don't you think the spacers are a bit to wide,
because 20mm all around the speaker is a lot
of capacity which does not make any sound,
but is seen from the amplifier so: wasted efficiency.
For your tweeter I would cut them in halves.
Frank
Frank
Hi Frank,
The choice of 20mm wide spacers came from:
1. Trying to cut 1000x10mm strips resulted in uneven strips as the plastic moved in the gigant metal sheet cutter. Even with 20mm strips I have to stand on the sheet while a helper cuts the plastic. A saw could be used instead but cutting was so much easier.
2. Using 5mm aluminum tape for the "EHT-loop" results in two 7.5mm strips for gluing the Mylar to the spacers => higher tensioning possible.
3. With the intended frame, I'll "wedge" the panels in slots and the width off the spacers is needed for stability.
/R
/R
Anyway at least you are doing some real things,
it seems that most members here are only discussing it.
I wish you succes and good luck for your projekt,
and if you have done everything all right, you will be
very surprised!
Frank
very surprised!
Frank
Update:
PVC strips will not be used as spacers! 😡
Glued a midpanel yesterday evening using contact cement. Everything stuck together as suposed but it it so much easier using tape and it bonds better to both the film and stators.
Got a midpanel( 200x1000mm) working, using 1mm tape & 5µm Mylar. F0 is ~250Hz and it measures good up to abt. 17.5kHz where my sound card starts to drop off!
/R
/R
Got my "large" panel working last night.
400x1000mm, 2mm foam spacers, 5µm Mylar, 3.25kV bias
Measured f0 ~70Hz and the panel is usable to abt. 7.5kHz where I hope my tweeterpanel will take over!
/R
/R
-Finaly, all panels are done! 🙂
Tweeter panel under test:
NowI have to get them to play together.
Any sugestions on a sutible x-over ? ( 150Hz & 7kHz)
/R
/R
Very nice job!
If I may suggest, it would be convenient to have an active crossover (like a cheap Behringer) so you can dial in the crossover frequency, slopes and panel attenuation quickly. Just to find out what is needed exactly.
If you use one step-up transformer per panel you can attenuate with the winding ratio's and use the transformer properties as part of the filter. Together with a couple of resistors and capacitors this should make a nice crossover.
Tnx!
I would like to keep the filter passive for now, but a active x-over is absolutely in the future plans!
Got a tip on a Swedish forum to look at how Quad solved the xo issue. So I'll try some simple RC-filters this evening! 🙂
Running tests I'm using 2x small 100V PA transformers, but will wind new toroids when I have a frame made for testing both panels.
/R
/R
Measurement is done using Tombstone, DIY mic and a DIY amp.
Mic is placed near the panel ( abt. 20-30cm) and the panel is sweapt from 20Hz to 20kHz.
Not scientific, I know, but it points me in the right direction! 🙂
/R
/R
It looks really nice.
How does it sound?
Will you be using two different transformers for the big and small panels?
Wachara C.
How does it sound?
Wachara C.
- Planars & Exotics
- My ESL attempt
