• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
MY ES9018 NO NFB AMP OUTPUT
主板4.jpg主板5.jpg底面.jpg改良型线性直流稳压电源原.jpgTHD.jpg参数.jpgThis is my ES9018
OK Handak, as SY is clearly saying you posted an ad for commercial equipment, may I ask you some questions:
where can I buy this kit?
is it delivered stuffed or do i have to solder?
How much will it cost, delivery to europe.
Are the clock and the different supplies fed from different supplies?
Do you supply a schematic before buying?
This circuit is indeed a 'Non-feedback AMP' is an amplifier and a buffer for the LPF
Indeed difficult to achieve extremely low distortion, and here more stringent paired transistor and careful debugging, circuit similar to the PHILIPS LHH-900 CD PLAYER AMP
Could it be that K213/J76 transistor load can not afford to 600 ohms?
This the REF-2012 DAC does achieve extremely low distortion.
REM FIREFACE 400 & REF-2012(ES9018)
CDPLAYER and REM FIREFACE 400 to connect the REF-2012 (ES9018) to play.
Play CD & 24Bit/192KHz WAV performance perfect..................
A BOX FOR REF-2012
A BOX FOR REF-2012
