My DIY WTL Tonearm
Here is my version of Bill Firebaugh's Well Tempered Labs tonearm. This arm is a 10.5" version and I am using a carbon fiber arrow shaft for the arm tube. Here are a few pictures of it with my Dual 502 driving the records.
I hope it is an improvement from the original tonearm. It looks over 12 inches long.
This one is the 10.5" version. I will be experimenting with 12" and 14" arms through the winter. I will post updated pictures as changes and time goes on. Once I figure out which arm is better then I will build the rest of the turntable around the arm that I choose.
The well tempered idea was and is a simply brilliant way to do a tonearm.
Your way ahead of others scrambling to do the same thing with complicated bearings with such Rube Goldburg thinking leading to mental masturbation and a swift self pat on their back!
(Well) Done enjoy!
David
I will try and take more pictures as I go. Some times I get going and forget to take pictures. When the project is done then it's too late. I will have chance of taking pictures as I go as I am going to try a 12" and a14" arm.
We gotta have one of the arrow shot!!!! I'm thinking that we put golf ball on top of Zen Mod's head and see who comes closest!!! 😀😀😀
Here I have the arrow shaft set up in the mill to grind a 19 degree angle for the head shell.
Here the head shell and arrow shaft are ready to be glued. The glue I used is sold by Brownell's, it is called Acra-glass Gel. It is a 2 part epoxy type glue with very low shrinkage and extremely strong.
And here are a couple of shots with everything glued up and finished to final shape.
