Here are some pics of my DIY Turntables and DIY tonearm.
A really good job!
How is the platter bearing made?
Wooden platter
Roger,
My congrats! Excellent job, very stylish also!
Now a question: how yor platter is done - glued layers I guess, what kind of wood and glue? Glueing technics?
Regards,
Michael
Roger,
Regards,
Michael
Thank you !Very very nice looking
very nice job, deserves something a liitle more special than the AT95E IMO
As soon, MC Cartridge !
wood is MDF of 22mm x4
Glue is standard woodworking glue (Colle vinylique blanche) in french !🙄
ballasted with lead !
Weight of platter : 22 lbs
Weight of TT : 77 lbs
@Roger,
hello,
nice piece of work!
may i put your pictures and description on my diy turntable gallery (located at www.krishu.de)?
Would be really appreiciated!
you may also answer via email (button below)
Cheers
Christian.
hello,
nice piece of work!
Cheers
Christian.
krishu said:@Roger,
hello,
nice piece of work!
Cheers
Christian.
well on Christian, any problem!!!
The arm in details:
Basic materials:
- PVC pressure Rings (yes yes! you read well...)
- Set screw stainless "machined" in points for the pivot
- Stopper of clock industry out of bronze bored very fine for the horological jewel and inserted in rings PVC
- Arrow tube aluminum for the arm
- the carry-cell "worked" in a piece of magnesium (1/3 of the weight of aluminium)
The rings with assembled pivots and horological jewels, the tiny trick that you see on the right of the set screw is a stopper of clock industry (My grandfather was a clock and watch maker...)
Wire of flexible wiring and very end bought in a retailer of electronic component of my area (did it find any more the reel, nobody any more does not ask any him...) 1 ml = 1,5 euros
I on kept well only 4 wire for the cell + 1 to connect the arm to the mass.
The mechanism of the arm:
- Counterweight of the threaded bored stainless arm
- Counterweight the antione out of stainless, aluminium pulley, the wire is a hair!
Details of the magnesium carry-cell equipped with a AT9E
The arm finished, finally almost...
Basic materials:
What a piece of junk!
Just kidding, it looks unbelievably good.
The best diy tone arm I've seen by far
Unbelievable!
What a nice piece of engeneering!
Don't you guys hate yourselves do not being able to do
something of this caliber? I do....
Very nice and sensitive balanced design. But one question : how is stabil rotation with pickup on plate - I see there very thin belt ?
Thank you with all for your compliments !!!
The sound is very fine, very deep, like good Cd with more details, the band-width seems very wide !
I bought the 30TH anniversary "Dark Side Of The Moon" Pink Floyd, I was very impressed by the dynamics and the richness of details which a LP could contain!!!
the turntable is very quiet, with a new LPs, it does not have there no noise, no rumble, no resonance!How does it sound?
Not for the moment, I did not considered to be it useful.Did you balance the platter?
not of particular reason!Is there a particular reason the platter diameter is so small?
With inertia, the plate is very stable, the belt is wire to sew for leather!how is stabil rotation with pickup on plate ?
🙂What a nice piece of engeneering!
roger waters you fab turntable
your turntable is Wow!!!!!!
i have a question. several actually??? how are the cavities, spaces
where the lead shot is loaded arranged. Is the mdf only used on the edges of the plater and the base or plinth or is it in individual, compartments, ie more than one compartment per layer or several layers. I ask because even with lead shot cavities do resonate!!
How did you make or get the bearing made???
The final question, just what does this yummy turntable sound like!!!!!
stunning but how would you describe it???
Fantasia
Milwatos@yahoo.com.au
Fantasia
roger water great turntable
well, that answered my question about sound and a great
description of the sound!!!!!!
your description sounds just like what i remember a Golmund
reference from the 1980s sounded like and that was expensive
im sure it sounds just as good.
What did it ending up costing you???
i ask because im building something myself but nothing as
impressive as your machine!!!
the price of new turntables is just scarey
fab, i dont have enough superlatives.
fantasia
fantasia
approximately 250€ (300$) of materials costWhat did it ending up costing you???
Roger:
Is it possible for you to post the dimensions of the parts you made for your tonearm? It is a very impressive accomplishment and having the drawings/dimensions would allow me to cut to the chase. Hopefully, I have something to contribute to improve upon it. Thanks.
Jim
Of Course !
http://www.nicoll.fr/pub/catalogue/framer_cat.php?niv=4&fampr1=1002&fampr2=2014&fampr3=3032
- Analogue Source
- my DIY Turntables and DIY tonearm
