I reckon Savu means the same as I'm going to say.
Can you show your circuit diagram with a WHITE background, not black, please.🙂
It's a complete pain in the eyeballs to examine, as you have it.
Sandy
My software doesnt allow a white background.
I use black backgrounds because white ones give me migraine.
@ savu: I'd totally forgot about this... Maybe because i didn't need it yet. I will build it sometime, but no idea on the ETA.
Here is a similar project with discrete parts,
+/-45Vdc supply, 150W RMS into 4 ohm, 250khz, 0.31% THD @ max power, 1.6W dissipated per Mos Fet.
It only exists in LTspice, I never built it.
savu
Savu!
Amasingly simple, and it may wouldn't have blown, if D1 had a higher voltage rating. Decoupling capacitors are needed on supply rails. (I would call negative rail Vss instead of Vcc.)
hello Pafi.
i know that the caps are missing but i never use them in simulations.
i wish i could have the time to build this and see how it behaves. 🙁
regards,
savu
regards,
savu
I found my output filter inductor was cooking at 200 degrees C at idle.
Found the oscillator frequency to be too low at 140KHz.
Increased the speed of the oscillator to 220KHz and the inductor doesnt get so hot.
Noticed a faint whistle in the background of the audio and this was fixed with better decoupling on the IR2113 VCC rail close to the regulator.
