Brian,
I received the box of components first thing this morning,thanks very much.
I must say your D10.1 (pictured) does look very interesting - any reviews anywhere ?
Hi Danny. Thanks for letting me know you got the parts. I didn't think you'd get them until Friday at the earliest. The US postal service has actually been pretty good with shipments lately 😉
Mike posted his short and sweet review on the previous page, and I think I posted some thoughts on them back near the beginning of the thread. One other person has an old kit (as shown in the above pictures) but hasn't built it yet (that I know of). Once these latest kits go out and get built you'll hopefully see some more listening impressions. The boards are supposed to be delivered today but no one will be home to sign for them so I won't get them until tomorrow 🙁
Joined 2002
Just thought i would offer too. I have a smd soldering station and proper layout to do smd soldering if yu need help i can also help. I just soldered a few hand full of smd Mini aleph's 🙂
Jase
Jase
I stayed up way later than I should have to get these built, so you're getting some pictures because I don't want to be tired tomorrow at work for nothing!
Here are the first two D10.1s to be built. I'll test them in the evening tonight after work and if they work, will collect payment and ship out the kits next week.
I got to give them some quality playing time and if they sound this good not broken in then they're good to go! I probably said this before but the quality of the bass is very good, and the top end is not bright or lacking in any way on either pair of 8 ohm 2 ways I've auditioned them on. Full range drivers with a rising impedance may cause the frequency response to rise a little bit, but that's no biggie for most people because full range drivers often lack that top end sparkle anyway.
Honestly, these latest boards are a little bit better than the previous version. For a small to medium room with sensitive speakers 7-13W is plenty to get to adequate volume levels unless you really like it loud. For that I'm working on seeing how bridged stereo modules sound 🙂 The old modules sounded just as good when bridged so I would expect the new ones to sound equally good, only with about twice as much power into 8 ohms. 14W should rock the Klipsch 2 ways downstairs quite nicely.
It may also be possible to parallel these modules for more current into 4 ohm loads, but I need to think about that a little more before going ahead and ruining a bunch of chips.
Joined 2002
I think i might try a set soon. Im looking at it because i don't need that much power for my speakers @ 92db efficant 🙂 so i think 10 watts is plenty.
Interesting observations, Brian. The lack of input coupling is one obvious advantage I'm sure you're hearing.
By the way, what kind of output filter capacitor are you using?
BWRX said:And here's the new module next to my old tester module.
They look good, Brian!
Jason, depending on your room size they're fine for use at normal to moderate listening levels with speakers that sensitive. 7Wrms max into 8 ohms (the max power rating of these modules) doesn't seem like a lot but it's enough to reproduce some very tough organ music (Bach's Toccata and Fugue) at more than adequate levels for most people (excluding punk rockers and deaf people).
Tom, no coupling cap is indeed advantageous. You can still add one if you prefer the slight coloration it adds or want that DC offset peace of mind, but it may add a pop on start up or shutdown like with the Tripath modules. I haven't used one and don't plan to. The output filter cap is a 5mm lead spacing 5% MKT (metallized polyester film).
Mike, thanks 🙂
I hope to have another pair finished off by Sunday so I can test out a bridged stereo pair.
P.S. I'll be away today so I don't get back to you it's because I'll be up at Penn State getting rained on at the football game 🙂
Mike, thanks 🙂
I like that later version.... 😀 nice for room/bedside amp.... run with MP3 player.. played with some classical.. and off you go to dreamland.... zzzzzzZZZzzzzzZZZZzzz
Thanks guys.
Don't let the size fool you. These little modules aren't just for a second cheaper bedroom or ambiance audio system (although they'd work just fine for that sort of application). They will rock your speakers if they're sensitive enough.
I was blasting music by Orgy, Linkin Park, Kid Rock, and Eminem earlier and you would not have believed that these little modules were driving the speakers if you were brought into the room blindfolded. I was shocked and I knew exactly what was going on! 😎
RX5 - Thanks for posting all the info about your DIY class d amp in your thread. It's a very interesting read! 🙂
Hello BWRX,
never said anything about "cheapness" 😀 I know they sound GOOD...
hehehe
I was indeed looking/planning to make a 10-20W D-amp for room... I know its more than enough... esp the size of it(board)
BUT.... I also know I have to order those chips abroad...
practicality, use what is locally available.... whew
BUT I do wish I had one ..... love to put it in my room
regards,
Raff
hehehe
regards,
Raff
BWRX said:Thanks guys.
I think I'm the only other person to have built the first version so far.. and I can agree with him on all points!
Yeee Haaaa..... I can't wait!
Any idea when the next batch might be available?
With the good input about these chips...... and your design of course, I'm already making plans for a multiple channel amp.
I'm waiting to get feedback from you guys to see if it would be possible to make any further improvements before going any further. As it stands, I'd really want to do a small production run, but it would be easier for me to foot the bill if I knew more people were interested in these modules. Plus, I obviously think they sound fantastic, but that's just my opinion. I'd like to hear what you guys think of them as well, as I value the opinion of my fellow audio enthusiasts.
Brian, I would be intrested in a pair of your amps. Are you any closer to a price and next run?
Chris
Chris
Hi Chris. I sent you an email asking if you'd like the one kit I have left since someone backed out at the last minute. If you'd like it please send me an email through the forum. If Chris doesn't want it then it's up for grabs.
To everyone who has a kit on the way - I just sent each of you emails containing documentation that will help with assembly.
- Class D
- My 10W Mono Single-Ended modules - D10.1
