Multiple small subs will never have the impact of a large sub (PPSL design)
Yeah so the at best, 3/8" thick piece of glass that is at best, 2 square feet in surface area was making the 90 something dB 50 foot bass wave bounce off of it enough to change the response at the LP significantly.
It must have been that transparent aluminum stuff from Star Trek where they saved the whales. 🙄
I'd vote for multiple smaller subs running in mono. Here are some spectrograms not to be fully subjective.
Two subs are located in corners of the front wall. Single subs give the following picture:
attachment.php
attachment.php
If you're not familiar with spectrograms, these type of charts show if every note is playing at the same time and how fast they are fading. Ideal spectrogram will look like this:
attachment.php
Every note is playing at the same time and immediately disappears. Red zone becomes wider towards the lower notes because lower notes have longer waves.
Running two in mono mode with a delay for one of them, gives much smoother bass response:
attachment.php
Third sub make the spectrogram is little bit better.
Reactions: taloyd
