MTX Thunder Power supply drive issues.
Pin 1 to R213
Check D118 and D119 zener diodes, these provide the +/- 15V to the base of Q4 and Q6 for voltage regulation to the various op-amps. D118 (feeds base of Q4 mpsa56) dies more often then D119 (feeds base of Q6 mpsa06). The part number for D118/119 is MMSZ5245B. Make sure to look at marking to install correctly. D118 is - voltage, D119 is +.
