MTX Thunder 5601
1:1 is correct.
With a multimeter set to ACV...
Reading from B+ to emitter leg of the driver transistors, I read 6.14v.
Reading from the source leg of the power supply FETs to the gate resistor (side driven by the transformer), I read 6.17v.
These were taken with the B+ voltage set to 10.25v to force the duty cycle to as close to 50% as possible.
What I find different on the Sony board is the transformer is driven by the driver collectors instead of the emitters, otherwise the transformer pin configuration looks the same where as the outer pins are at ground / source like in the MTX.
Are the gate and source for the adjacent pins in the sony for the same FETs?
Reinstall the transformer in the MTX and see if you can find any 1:1 voltage primary to secondary but try all combinations on the secondary windings. I think you'll find the equivalent voltage between the source and the non-adjacent gate.
In the Sony the adjacent pins are not for the same FET like they are in the MTX.
You are correct, measuring across the non, adjacent pins I get the expected 1:1 voltage.
Here are the pictures with corrected labeling.
I haven't had the chance yet, but I was thinking swapping the two inside pin locations on the secondary is the fix.
It will probably be couple of days before I can report back on it.
Sorry about the slow pace of progress.
With B+ set at 10.25V I measure 7.32VAC B+ to driver emitter and 7.31VAC Source to transformer side of the gate resistor. The amp is now producing +/- 50.5VDC rail and rises when B+ is increased. The power supply appears to be operating correctly now.
I have run diode check on the LED's to to confirm they all can light up, green, red, and blue. All of the PZTA06/56 check OK in circuit. What do I need to look at to get the colored LED array functioning?
At approximately 13.8V in, I get ±60v
Yes, here is what I have on all pins
Bottom TL074
1: 1.976
2: 1.976
3: 1.920
4: 14.35
5: .950
6: .692
7: 5.011
8: -9.60
9: .948
10: .948
11: -14.98
12: .009
13: .010
14: .607
Top TL074
1: -11.16
2: 1.125
3: 1.022
4: 14.39
5: 2.503
6: 2.295
7: 11.03
8: 11.05
9: 2.296
10: 3.847
11: -15.00
12: 2.096
13: 2.858
14: -13.73
